Tires wearing bad on the inside
purevenom1
My rear tires are wearing something terrible on the inside of them. This was also doing it before the lift. Tried to check for play in the axle bearings but didnt notice anything. Only other possible thing I can think it is would be the rear axle housing is bent but there is really not much vibration other than what is coming from the front. Any ideas to check cause I need this fixed ASAP.
Again it has been ALIGNED. It was doing this before the lift and 33x12.5. Just did notice it as much. The truck has 1 new tire, 2 fairly new and 1 somewhat worn.
Have it aligned again. This time have a 4 wheel alignment done. And report back.
Will prob go back to get it done after I change out the bushings in the control arms anyway. They are shot. Plus the drop brackets for the lower arms are moving sometimes due to the worn out bushings in the front I think cause there is alot of movement in the control arms. Going to install urethane bushings and tack weld the brackets so they dont move no more.
if they are wearing in the rear it can only be 2 things
1. bad wheel bearings that are allowing the axle to squat
2. bent axle
allcarhistory
