Tires
bgannon13
I have a 99 TR4 with 2007 TR4 rims (17"). Came with 265/65/17 tires. Question is will a size 265/70/17 fit without any rubbing and without doing a lift?
I recently switched to a similar set-up with split spoke Tundra/Sequoia 17's. The 265/70/R17 will fit fine for normal day to day driving without rubbing. They will rub slightly at full suspension flex if you plan on going off-road (with stock suspension). So, if you don't plan on doing much off-roading they will be fine.
On my 99 I went to a 245/75/17 Goodyear Wrangler Dura Trac on 2011 17/7 4Runner wheel, same backspacing as stock 16" wheel, plenty of clearance with no lift. Also these wheels clear the 2005 Tundra brake upgrade.
Wheels
2011 4Runner 17x7 with Goodyear Wrangler Dura Tracs 245/75/17 on my 1999 SR5
