TomasAllan's Build Thread
I NEED to regear. I can deal with losing top end. Mine is a slug. I will definitely be going 4.56 and lockers front and rear. But wedding comes first.
I would say go for it if you feel the need. If you can deal with the gear hunting and sluggish response then keep it stock.
To re-gear or not to re-gear?
Go to 4.56?
Its become heavy.....
Transmission hunts a lot, specially when loaded during long overlanding trips....
Feels a bit under powered.
My problem on the flipside..... I am an 75/85MPH highway guy..... I keep reading that I will loose that top end in which case I am not sure I can deal with that.... would hate a long trip at just 70MPH.... murder!!!
Thoughts/advise?
I'm on same boat ... I'm going 4.56 as well
And I'm a 80mph freeway driver.
supposedly using my old trusty gear calculator...
75mph w/ 4.56gears = 2515rpm
3.727gears = 2056rpm
4.88 gears = 2871rpm
80mph w/ 4.56gears = 2683rpm
3.727gears = 2193rpm
4.88 gears = 3063rpm
this is with a 32.71" inch tire like the duratracs...
I'm planning on purchasing my gear set in a week and half...
Incredible build sir...very impressive indeed. :usa2:
this is what my truck would be, if it grew up, worked out, stopped being lazy, and had purpose and focus...
and ive said it before...all from an SR5 /w 3rd row...into this incredible Zomie apocalypse survival rig...i LOVE that.
...not a TE, not a Limited, and not a Pro...SR5 dude...formidable right out the box.
Thanks Mike, yeah I am thinking I'll just go ahead in the next two weeks and bite the bullet.
That is not bad dude I can deal definitely deal with those RPM's, I thought I read somewhere that the truck would have a hard time hitting those speeds...... but if its just an RPM thing....
Running 33's now but will soon go a bit higher...... from 285/70/17 to prob 285/75/17 ....... and if I feel ballsy might even try 305's but there is a lot of cutting that will take place at that point.
Thanks Patrick, indeed!!!
Moab - white rim
I though I'd share some more awesomeness from my trip a few weeks back ..... next one up possibly October "Yellowstone" with [MENTION=632]toyo[/MENTION]
HID's / Clear Projector Lens and some Halo Action
HID's / Clear Projector Lens and some Halo Action (switchbacks)
Got it all at "The Retrofit Source" here in Atlanta, my bud Matt Kossoff hooked me up, these guys are super awesome with excellent customer service, check them out, I also swapped all my internal LED's with them and I am much happier now that the stuff I had before.
Go to 4.56?
Thoughts/advise?
So anyone else has any advise/feedback/heads up/gotchas on Re-Gearing?
- Thanks.
- Thanks.
You will not have a hard time hitting 80. I have bigger tires and more weight and can easily go up mountain passes fully loaded with RTT, 4 adults, stuffed inside to the gills, spare parts, full fridge... and maintain 70 on a 5-6% grade in 4th (yes I am over 3k-3.5k and as much as 4k rpm which only affect mpg not the engine). The top end that you lose is probably the part that you don't want to get to in a lifted, modded fat pig. Easily can cruise on the interstate at 80-85 but your revs will sound fairly loud and mpg will suck more due to the increased rpms.
The biggest difference is that I don't get much better mpg on the road (its better but not a huge difference). I hover fairly consistently around 14 (manual calc because the gauge is off by about 7%). One strange thing is that with 34s it is better than it was on 33s. on 33s I would get slightly less MPG but more throttle response. FWIW, I drive for the most part averaging about 75 because I just feel safer going slightly slower than I would otherwise given my weight, center of gravity and lack of sway-bars.
PS. when I'm on the freeway, hands free cell phone is a joke. My rig is so loud people can't hear me well. lol
Thanks so much Ben I appreciate your feedback.
Some Lights Upgrades
So I went for a full HID Conversion kit from TRS (The Retrofit Source) - The Retrofit Source Inc - Amazing group of guys and cool products.
HID Kit
Halos
Etched Projector Lenses (TRD)
LED Replacement Fog Lights
36" Combo Light Bar
All internal LED's
<img src="https://farm6.staticflickr.com/5659/21709412668_8b644aa08c_c.jpg" width="1024" height="768" alt="2015-09-28_12-04-29">
<img src="https://farm1.staticflickr.com/661/21885283352_6c2ec18364_b.jpg" width="768" height="1024" alt="2015-09-28_12-04-06">
<img src="https://farm1.staticflickr.com/707/21897251325_cf01bc2380_b.jpg" width="1024" height="768" alt="IMG_3721"></a>
<img src="https://farm6.staticflickr.com/5678/21276150463_cdb1484b2a_b.jpg" width="1024" height="768" alt="IMG_3722"></a>
<img src="https://farm6.staticflickr.com/5719/21885690192_004371b216_b.jpg" width="1024" height="768" alt="2015-10-02_16-33-47"></a>
<img src="https://farm6.staticflickr.com/5790/21709592410_2042274d99_b.jpg" width="1024" height="768" alt="IMG_3723"></a>
:wave:
ARB Twin Compressor on 4x4Labs Bracket
So finally bit the bullet and went for on-board air.
Went for the ARB Twin Compressor
Luke at 4x4Labs is now selling the compressor mount brackets, I think has some in stock already powder coated and all, direct drop in, no moving or modifying anything, all bolts and nuts included, mounting the compressor took 15 minutes, wiring on the other hand a different story :-)) .... I did not go for the manifold as I have no plans to run lockers.
Simple yet impressive work from 4x4Labs.
<img src="https://farm6.staticflickr.com/5741/21906591281_a1668e3725_b.jpg" width="1024" height="768" alt="IMG_3708"></a>
<img src="https://farm1.staticflickr.com/747/21274169434_bf9009e154_b.jpg" width="1024" height="768" alt="IMG_3707"></a>
This thing is very impressive and fast filling up.
Additional parts were:
All from Amazon
AirPro PUR-14X50-B 1/4-Inch x 50 Foot Polyurethane 250 PSI Air Hose
Legacy A73457D Color Connex Type D 7 Piece 1/4 in. Red Coupler and Plug Kit
Amflo 150 12" Straight-on Tapered Chuck Inflator Gauge - 10 to 90 PSI
Looks great! And good tip on the bracket. I want that compressor when I regear and lock but hadn't found a decent bracket.
Two questions for you on a different topic:
How is the wrap on the hood holding up?
How is the rear bumper holding up? Any rattles or squeaks from it? I like that bumper but am leery of just pins holding arms in the closed position. Seems like it would rattle a lot.
Thanks in advance!
Wrap is holding up perfectly but again I had it professionally done so not my work, a year later and it is perfect still.
Bumper is awesome and no rattles at all, I've had squeaks twice and it was the right arm (tire carrier) giving up a bit and resting on the base..... mind you since I've have it the car has been out west to Moab two or three times and also Georgia mountains and stuff so if you ask me is awesome, we took care of the squeaks by just readjusting the arm.
Headed out west next week - 10/8
So a couple buds from ATL and I are headed out west next week and wondering if anyone will be out or near the places we'll be.
Plan is to leave ATL on the 8th headed to Yellowstone with a tentative arrival of Saturday 10th (sometime), then Tuesday the 13th head down to Moab (Needles this time - Elephant Hill) and Thursday head to Telluride (Blackbear/Imogene Pass).
You never know when someone else will be out there so I figured I'd post this just in case.
@wfo9
AndiGarage
