TorqueOfTheDevil’s Build Thread ..::1UZ-FE VVTi Hilux Surf::..
I think that is *most* of the various bits up to date... a bit of an information overload!
My latest project is the Rear Axle....
After upgrading the Tundra fronts I wanted to get rid of the rear drums...
They are not that bad in all honesty.. perfectly adequate.. but drums are a bit... 1950s.. so after some searching about I managed to source a Landcruiser Prado rear axle.
I specifically wanted a Prado one, as opposed to the natively sold Colorado as all of the UK supplied trucks had E lockers.. most of which had rusted away.
I originally wanted an E locker years ago, but the more I thought about it, the more I thought that an LSD like a TrueTrac would be more suited for me...
My logic was an E locker is great that one time when its locked off road... all other times its just an open diff and more to go wrong... I do struggle slightly with wheel spin... I often try to pull out of a side road to filter into traffic and end up sitting there spinning my inner tyre looking like an utter douchebag (yeah, lifted trucks are NOT a big thing here in the UK, people think its weird).. for this reason I figured a Trutrac would be better all the time, on road and off road, just not "as good" off road as a E locker, air locker or Detroit locker...
I then decided to get a front one too... because.... matching.
I noticed that the Landcruiser axle had a different final drive, so I was going to need to regear my front to match... at this point I decided that what I actually need is to regear both...
I initially settled on 4.56 ratio gears, as although I run 33s, I don't suffer from acceleration problem, but it is quite loud when cruising... My girlfriend and I are planning a road trip to Poland in the truck this summer, so I thought I'd be sensible and stay 4.56.
I wasn't... Randy's Ring and pinion (the first people who would deal with, so many other suppliers ignored my emails for $2000+ of business!) were out of stock of 4.56 that day so I went 4.88... I have the extra revs to make up for it, I figured at 80 mph cruising... its a 500 RPM difference.... and my truck will get there faster... so.. go for it!
The parts arrived this week and are still sitting in my living room.
On inspecting my "new" axle I jet washed off all the mud and went over it. unfortunately the drain part of the right hand side upper link mount was blocked.. it had been left with sitting water in It and was quite rusted.. I say quite rusted, it would probably be ok... but I have been told under heavy acceleration I pick my front left wheel clean off the ground... I'm not going to risk that part failing and possibly me killing myself, or worse still my rig :D
So I accidentally ordered a new one..
So shiny and new and not rusted!
I also needed to redo my rear axle links. I'd say they were the original factory fitted ones... I've done 120k miles now.. so the plan was to remove, paint and polybush them... until I saw something else on that universal portal of most things I seem to buy for my truck... Ebay.
Full Toyota seals, disks, pads, fitting kits and wheel bearings have arrived at my dealership today.. I'll collect on Friday..
Then its time to get rebuilding! Watch this space.
I get a tingly sensation in my trousers while reading this thread, oh my.
Gotta love JDM wheels with portuguese and german writing on them,Raguna isn't the only Japanese wheel company guilty of that LOL
Campeao do Mundo - world champion
das beste all der welt - the best of all the world
Yup that always cracked me up...
Toyota are guilty of it themselves with their very odd English sayings.
JDM MR2
JDM Estima
They had an equally insane one for the Hilux surf, but I can't find it!!
Anyway...
I got more parts today!!
I also popped into my local transmission shop to get a quote of getting the gears set (pinion spacing and backlash) on my front and rear diffs.
I'be been considering a Prado axle for a while, where did you get yours? To my knowledge they never had them here in the U.S. Was the Prado locally sold there in the U.K.?
This build makes us bolt on builders look pretty weak... :hail:
Very nice rig and I look forward to seeing more upgrades in the future!
Love your truck and what a built all most like porn:girl: wish i had the talent , time and money to do a built like that......:biggrin2::yo:
That rear spare tire carrier is awesome! Anyone know if it can be retrofitted to a US model?
I've seen it done, but there will be some fab work, as the rear wing under the tail light has a recess for the lower mount, it is also reinforced inside.
Thanks!
No changes this weekend as I had to go to a wedding :(
Progress has been slow again..
More stuff arrived! Local couriers now all hate me..
4Crawler .75" prop shaft spacer..
At rest I could almost see my splines, so hopefully this will help fix that. and it made sense to do it now "while it was all apart"
I started last weekend and removed the front and rear differentials, to get them ready to send to the gear shop... (who annoyingly said they would call me back but still haven't...)
On Draining my front diff there was a clunk and two teeth fell out!
I added it to the one I kept as a trophy last time.. oddly 4x4 still seems to work fine, and I've not noticed any ill effects or noises... I guess I chose the right time to rebuild.
Front and rear diffs removed ready for delivering to the shop.. They are heavy!
Not sure if I should removed the ADD from the front diff, or just leave it as it is. and let them deal with it all.. I will remove the front mounts though.
Can't wait to get it all back together. I hate it being apart!
Go home HiLex. You're drunk.
Currently sitting on axle stands with plastic bags over the front hubs to keep the rain off and the wheels placed over them to keep it all in place.
