TOTAL CHAOS - Chromoly Adjustable Rear Links
Novice mechanics question- The shop that installed my set of these didn't do the modification to the bracket on the lowers so I can get at the zirc fitting. So I'm going to need to drop the arm to grease it and then modify the bracket per the install instructions. What is the "Safe" and easy way to do this before I attempt to pull the bolt out? Pull the tire and put the axle or the frame on a jack stand? I don't need the axle shifting making it really hard to get the bolt back in.
Thanks in advance
Ken
Sorry we never got back to you.
A ratchet strap/ tie down from the rear axle to the frame will help prevent shifting
Hope you already got it taken care of ;)
Upskirt shot of our Chromoly Adjustable Rear Links gettin' dirty!
4Runner - Chromoly Adjustable Rear Links
Since I got my set used, no install instructions would you mind posting the pdf so I can take a look to do that modification the post above was talking about?
mek
