TOTAL CHAOS Upper Control Arms
Just ordered a set of your UCA's yesterday. Just want to double check that these are adjustable. They will be going with the Toytec 3inch TRD Pro kit if that makes a difference.
These do have alignment adjustability with the Heim Pivot UCA having maximum adjustment. These are designed to allow vehicles with 2.5-3" lift to get back into factory alignment specs with ease. You're good to go!
TOTAL CHAOS
WWW.CHAOSFAB.COM
My UCA's arrived today. I got my tracking numbers mixed up so they were always suppose to arrive today. Here are some photos of them, will post them on the truck next Friday after install and 285's. They came extremely well packaged from TC and the craftsmanship on these is top tier. Also sweet poster and stickers!
Awesome!!!
TOTAL CHAOS
WWW.CHAOSFAB.COM
Do you have a recommendation on how to clean out the zerk fitting. i can't seem to get the grease to flow into the zerk and just over flows around it. the other side works just fine.
I follow your instructions provided.
I've also used your uca for my 1st gen tacoma back in the early 2000s.
love your guys work!
Grab a paperclip or pick and press on the center of the zerk fitting. The zerk might be clogged or stuck. It should clear or release the pressure. If that doesn't work please let us know. The zerk might have to be replaced.
TOTAL CHAOS
WWW.CHAOSFAB.COM
Dual Front-alignment 03' Sport V8-"Pearl"
Just got back from Firestone-Merritt Island, Fl. My alignment tech for a couple decades now, Steve Locklin earned his $20 tip, and dialed her in perfectly. He has done lifted trucks now since the 70s, even owns a lifted vintage mid 60s Ford, and has been doing my 5th gen w your UCAs for years now. Gave me as much Caster as he could to help clear the secondary reservoirs in the back of the fender well.
Pre weld mock up-Tower Gussets, Dual Shock Hoop, and Cam Tab Gussets.
Alignment tech said the Cam Tab Gussets worked really well and I was only 3/16 toed out on my eyeball adjustment lol.
"Pearl" be Drivin Great! I guess you could call me a "Fan Boy".
Thank You Total Chaos!!
P.S. Congrats on the 5th place at Vegas to Reno!! Lots of hard work and determination goin on out there!!
Installed my UCA last week and absolutely love how it drives now. Coming from a lifted JKU on 37s, I thought my handling was just fine with bilstein 6112s and stock UCAs.
I was torn on the uniballs, but glad I went with TC. Great quality product, highly recommend it.
