Towing Capacity
mag3
Hello all! Long time no talk! :D
Hard to believe my 2006 4-runner will turn 9 years old this month, with around 120K miles. I know I'm in for a ton of maintenance soon, but today is another priority.
For the first time since I bought it, I'll need to use the tow hitch for a small U-Hall trailer (I'm moving long distance). So, for a 2006 4-runner Limited with V-8, 4-wheel drive, would anyone know, off hand the capacity of the tow hitch, so that I can size the trailer, and know how much I can load in it?
Also, For those experienced with this, how do you keep the trailer "secure" at the hitch point (within a "thievery" context)? If I'm staying overnight in a hotel, along the route, it would seem easy enough for thieves to unhitch the trailer at the tow hitch and cart it away. Do these trailer hitches or couplers come with some kind of secure lock that can prevent (or, at least, deter) that?
Any other tips/hints for a first time trailer tower would be greatly appreciated. :)
Many thanks. I'm sure I'll be back with other questions.
Regards,
mag3
Max towing capacity for your truck I believe should be 7000#, with brakes. It can be found in your owners' manual.
As for protecting against thievery, it depends on your hitch design and to what lengths you're willing or need to go. For a standard ball-hitch, you can use a regular ol' padlock in place of the securing pin in the latch, but they make special keyed locks for this purpose - not at all expensive, and quite a deterrent by itself. There are locking pins for the receiver adapter too, which tightly secure the adapter to the vehicle - a good idea for bike racks, or long-distance towing with lots of overnight stops, but maybe overkill for occasional towing around town. Finally, you can get wheel-locking devices as well if you want/need to go that far.
Regards,
mag3
Assuming that you have the factory installed V6 hitch, your Toyota recommended tow limits are 5K total weight, and 500 lbs tongue weight, and the factory hitch is NOT rated for use with a weight distribution towing system.
As for trailer security, you can get several different types of locking pins to secure the ball mount bar to the hitch receiver, and most trailer couplers will accept a standard padlock to secure the coupler release.
If you have little or no experience in towing, I would suggest, if possible, some practice towing a trailer before starting on the trip. Especially backing it up, that can be tricky for one who isn't experienced. I usually recommend finding a large empty parking lot to practice in. Keep your speed reasonable when towing, allow extra stopping distance, and try to plan ahead when making turns and pulling into restricted space areas so as to not get into a place you can't get out of.
PS: My bad, I miss-read the post, and thought you had a V6 instead of the V8. That being so, and assuming you have the frame mounted tow hitch, ebg18t is correct. Your max tow weight would be about 7k with a max tongue weight limit of 700 lbs. And, you would be able to use a weight distribution towing system, if needed. I stand by the rest of my post.
My V6 has been used as a tow vehicle for our 2 ton boat every summer weekend for the last 10 years. The truck handles the weight very well.
Suggestions:
1) Unless you're driving at 70+ mph with long coasting sections, leave it in 4th gear instead of D. It will prevent the transmission from shifting too much when trying to maintain speed.
2) When loading the trailer, you'll want slightly more weight in the front of the trailer than the rear. Technically, the center of mass should be at the center of the trailer, and just slightly in front of the trailer axle. If it is too rear heavy, you'll end up with a high speed swaying that is unnerving. Too much weight in the front, and the 4Runner will look like it's popping wheelies.
3) When backing a trailer, go slow, think about the result of every steering input before you do it, and use your mirrors. (assuming you don't have much towing experience)
Seeing as you indicated you have a V8 I doubt you have the v6 hitch mentioned earlier. All v8's I have seen have a frame mounted hitch. You are good to about 7000#. I would suggest a locking receiver pin and put a pad lock on the ball latch. Those uhauls have surge, so leave a little extra space. I would keep the truck out of OD and maintain a reasonable speed. Take your time, plan your route leave space when parking. most of all have fun
Another thing to slow a thief down would be, when you have the safety chains, WHEN PARKED OVER NIGHT, if you can pull them through a little more and put a lock on the chain so you can't remove them. Just remember to REMOVE THE LOCK AND PUT THE CHAIN BACK TO WHERE IT NEEDS TO BE BEFORE MOVING THE VEHICLE.
Many thanks, all! :thumb3: I am looking the various equipment options. All of this depends on what the realtor wants me to take out of the house and what is to remain for "show/listing/staging" purposes. If they say, "everything should go," (doubtful) then I may as well schedule the movers, immediately. If only personal things need to go, then I might want the trailer for those things that need to come with me initially, or that I don't want in the house while it's being shown/listed. I may as well move them immediately and get storage at the destination.
Suggestions:
Will do. The route does have a few rolling hills to it and most traffic drives at 65-70mph. I'd be happy driving slower, but it's also two-lane highway (each side) for most of the route and a significant truck route... so I either have to keep up or let them all pass. I'll probably be letting a great many of them pass. :noidea:
Understood. I guess I'll also have to consider having some things at both ends of the trailer to keep the "center of mass" actually in the center. :biggrin1: I'm not sure things in the center can be tied down to secure the other things in place.
I don't. And that's the greatest concern. This is the first time I'm doing this.
Thanks much. I have seen some things on Amazon in that regard (locks, etc.). I doubt I'll need to haul an more than 2000# if that much. The big stuff I'll wait for the moving van... again, depending on what the realtor says.
Excellent suggestion! Thanks!
I have a parking lot right across from my townhouse unit. It's filled with a bit of snow, right now, but I should be able to do some practice runs.
Not a problem. What does the "weight distribution system" do? Is it provided by the trailer company or do I have to look at renting it myself?
Thanks again all.
Common trick for backing up (that you may already have heard):
Put both hands at 6 o'clock position on the steering wheel. If you want the trailer to go to your right when backing, move your right hand up with the steering wheel. Trailer move to the left... move the left hand up with the steering wheel. Try to make minor adjustments.
Also, try to look ahead when deciding where to park. You may be able to get into a parking lot easy enough, but if there isn't a big enough area to turn around, you may find yourself having to back all of the way out. Sometimes you may need to park on the street instead of the McDonald's lot, for example.
good trick, I've been towing trailers since i was a kid (happens when you lived on a working farm) and never was taught this. i tried it once over this past summer, it messed with my head so bad i couldn't back the trailer up straight. old habits die hard lol
Thanks again all.
A weight distribution towing system is normally used when towing heavy or long loads (like a camper or long/heavy landscape trailer) If you estimate your load to be in the 2k range, you will not need it. And, it is not something that most trailer rental places will provide with their rentals. They may sell them, but it sounds like you won't need one.
Fair enough. Thanks again! :)
I wish I had that skill, I still have trouble backing trailers as guy that parks next to me in the storage found out the bad way. :ybrick:
lol wheelbase and trailer length are probably the biggest factors outside of driver skill that come into play when backing. short wheelbase vehicle and short trailer = fast jack knife. happens to the best haha
Mag3, one thing I forgot to mention (since you are new to towing) is to cross the safety chains under the trailer tongue between the trailer and your vehicle's receiver. Right chain on tongue goes to left bracket on receiver; left chain on tongue to right bracket on receiver.
Also, it's good to have a mental checklist in your mind of what needs to be in place, and to do a walk-thru of the checklist every time you start out. Stop for lunch? Do checklist before jumping back in to continue your trip. Every time you start back out, walk around the trailer and make sure:
  1. coupler securely fastened and locked
  2. safety chains attached and crossed
  3. jack stand up and secured
  4. break away surge brake cable attached to receiver (if so equipped) and not extended. There is usually a button at the bottom of the tongue to release it if it was extended. Press up on it to make sure.
  5. wiring harness securely connected
  6. lights, including turn signals, work
  7. tire pressure okay
The walk around only takes a few minutes and you will feel much more confident when you get back behind the wheel. "So far, so good."
Finally, when you do make a stop, check for extreme heat on the trailer wheels. If real hot, you may have a wheel bearing about to fail. Before leaving the rental facility, try to get some assurance from the proprietor that the bearings have been recently greased. It would be great if the trailer came with Bearing Buddies (where you can easily add grease without having to remove the wheel).
A tire or bearing problem can ruin a good trip, as well as overlooking any of the items in the above checklist.
All good stuff! Thanks very much! :)
I know what you mean, was taught turn the wheel opposite of where you want it to go. Got confusing at first, then became second nature.
Then came to difrent size trucks and trailers, relearn.
you should see me go from backing up the 4runner and a 20' dual axle to a garden tractor and a small cart. its almost comical
Ambrose67
