Toyota 3.4L 5VZ-FE Knock Sensor location
Yeah, I got it all apart and back together but I must not of seated an injector correctly because now there's a hissing sound and the smell of gas...damn 420 holiday
Mine did that too. I bet 99% that it's one of your o-rings. I had to replace mine after my knock sensor build because my passenger rear injector was leaking. Those seals are old and tend to rip when you pull them apart. Look at the link I sent before and it's got the part number for the o-rings.
hello everyone involved with this thread.
Looks like I might be doing a sensor soon enough. Had bank1 p0325 come up and assuming its the harness especially with the killer hot weather we have been having lately.
Anyway, any pointers from those that finished?
Good time to do timing belt and water pump as well?
Anyone have part numbers for both knock sensors and harness? Seems to be the best thing is when you have it apart to do it all at once?
Thanks!
Thanks!
It's not that difficult just time consuming. This fix deals with the top of the engine and the tb/wp is on the front so I can't really say it's a fix this while you're in there type of thing. I got my sensors from rock auto and my harness from Toyota of Dallas. I'll look up part numbers in a little bit, but if you look through my posts, I think I posted them somewhere already...
Sounds good. Thanks! Yea so I think I found the harness and sensor part numbers on another thread.
Just confirming. I only need "one" harness? 2 sensors?
Are both sensors the same part number?
I also read somewhere I'll need to order 2 new intake gaskets and another gasket I forgot what it was haha.
Yeah, only one harness and two sensors of the same part number. I didn't replace any gaskets and have had no problems.
Didn't have to change out the intake gaskets where the lower manifold meets the head?
Oh where the head meets the block? Idk I have to look it up.
But sounds good. Thanks!
Any luck on those part numbers? I'll probably go through camelback but they are asking 141$ For each sensor and 20$~ for the harness
Half day job?
Half day job?
RockAuto Mobile Catalog
I got the Artek at the bottom of that list. I got the harness off eBay from Tammy Grifith motors, but can't find part number for some reason...
thanks for your help!
just got down with the install today..
I will say, damn that was a long day..
but in the end im glad its over with. Now I can only hope for the moment of truth, got it all buttoned up and started it for a few minutes and runs fine but wont know if I cured the issue till I drive it around.
thanks for the help!
I got the sensor harness from that same ebay user and they ship fast!
thanks again!
for those of who are planning to do this in the future, here are the part numbers as it took me a while to search and find them.
sensor 89615-12050
harness 82219-34010
intake manifold gaskets 17177-62060
Ordered from Rockauto
$232.30 for (2)Denso Knock Sensors
$91.96 for (1)Felpro Intake Manifold Gasket set (2)Upper and (2)Lower all included in set
Ordered from Ebay from Tammy Griffith
$31.00 for (1)Knock sensor Wire Harness OEM
TOTAL:
$355.26
All the prices above are INCLUDED w/ shipping to me in Hawaii.
Probably going to be cheaper if you live on the mainland and if you choose a different shipping option. I went with all either 2 day air or 3 day priority mail.
Knock Sensor
So I got the same knock sensor issue, 1997 4runner 3.4L. I'm confused here folks, I tore off upper and lower intake, and still not seeing the knock sensor like the 1st pics of that beautiful engine in begining of thread. Do I really need to take even more off. Do I have to take off fuel rails and injectors? If so I'm not sure I want to do this, not to mention the wire harness looks like a complete headache to get thru. Dealership quoted me 2.9 hrs of work to do it, which seems way to little, if it is only that much I might just take it in the pants. Please help!
Your about half way there! After the upper and lower intake plenums come off the intake manifold needs to come off.
You can leave the fuel rails and injectors mounted to the manifold.
Just need to undo the fuel line on the driver side. Follow it out from the fuel rail.
Try not to disturb the injectors as the o rings get brittle.
Next is, if I remember correctly, is 14 bolts holding the intake manifold down.
12mm's.
Once those are off and all the hoses come off you should be able to slide it up.
You will need to take off the timing cover first as the upper coolant inlet is blocked by the timing cover.
Don't forget to take off all the injector clips and the coil pack clips so the harness is more maneuverable.
I just finished this job a few days back so it's fresh in my mind.
It's a good all day project. Not difficult. Just time consuming and need to be cautious about dropping anything down the intake holes
I've heard that the harness in this engine can become defective without triggering any knock sensor code. My T100 knocks under load when engine is warm, esp on a warm summer day. Local Toyota specialist basically refused to change the harness. All the usual solutions (spark plugs and wires, gas treatment combined with high revs to burn off carbon, intake manifold cleaning,...) have no effect.
If I were to do it again, I'd just change the harness to save some money. It's not a bad job if you were to do it yourself. It's just takes awhile. If you're paying a mech then I'd just replace everything while he's in there.
I'm sure it's possible to have knock sensor issues without a code. If you'd tried everything else, I guess that's the next step.
Could it be a timing issue or something else? Is you TB and WP up to date?
Thx for the info, I guess only other question I got is how hard is it to run the wire harness.
I know I'm late, sorry.
If you run it right, not hard at all. Mine was run wrong by a previous mech so I had to cut mine. The replacement was run correctly. There's a little cutout at the front of engine. East to figure about.
I ran these parts at rock auto, wow $80 for a sensor, anyone willing to swear by these parts, I just spent $196 just for 1 sensor at toyota dealership, glad I still got that receipt, the wire harness was only $31 dollars though, that was fair.
More Information for BECK/ARNLEY 1580780
All the research I did said that the Artek and denso were former/current toyota suppliers. Not sur about the beck
12mm's.
I removed the fuel rail to give my injectors a good cleaning, ended up with a few broken/brittle O-rings. I had a few generic washers laying around so I used them and they were hit n miss. I ordered some from the stealership and they quoted me like $5 for a pack of ten. They ordered the parts and then informed me the new little girl I talked to was mistaken. They were $5 each! So, my $5 project turned into $20. They originally said I'd have to pay for 10@5 but I convinced them to let me but 6@ $3 each.
Don't go the autozone O-rings. They didn't work at all, that's why I tried the generic ones...shoulda went OEM ftom the beginning.
timing belt was replaced at 110k. Didn't fix this mild knocking issue, which started around 85k. Not sure what WP is but I've had a beer already. This truck has had a lot of TLC, more than just scheduled maintenance.
So I'm out on vacation in Sacramento and driving in my po330 went off and truck ran like crap. Turns out it's a knock sensor. I have the tools but not much time. Dealer quoted me $940. Piss that's a lot.
So I'm trying to find an alternate method of getting this done.
I am very valuable of doing this job but time man. Time...
I'll probably have my sisters mechanic do it since I don't want to.
Dang man, ridiculous price. Is there anyone in ID that can help you? Sensors run about 135 (do both while you're in there) and 25 for the sub harness, 100 for the gasket set. Just keep resetting the codes. The ECM will use the other one to adjust your timing. Dang knock sensors kick these runners into "limp mode."
Should only take you about 4-6 hours. Best to you. OK here's my thread from back in the fall. http://www.toyota-4runner.org/3rd-g...nsor-0330-everything-replaced-puzzled.htmlHas a few good pics and some decent info.
alexaturner
