Toyota LED Illuminated Emblems!
Got around to installing the front emblem. Was an easy project and only requires the tabs on the OEM emblem to be cut off so the LED backing plate can sit flush. Pretty much looks OEM in the day, but when the headlights are on the emblem comes on for a unique look. Fit and finish was perfect.
[/URL]~original[/IMG]
The crazy glare is a product of the LED DRL's not dimming as I'm waiting on a dimming module. Sorry for the crap pic. I will do the rear emblem in red tomorrow and report back.
What size emblem did you order for the front and rear. Also where did you order it from
Ya I installed both and they are a one week novelty time untill the LED'S fry and water gets in behind the lens. Not worth it
Sent from my STV100-2 using Tapatalk
did you get the rear emblems installed?
Ok. I just installed the rear. It did not require trimming of the OEM emblem. Just Need to spend a lot of time removing old adhesive. Install was easy enough. I ran the wire though a guide hole for the oem emblem and ran the wire to the license plate bulb.
I don't know how long it will last. I washed the car afterward and there is some moisture in the plastic. Should of siliconed it before I installed it.
Overall looks good. Iam going to try to wire it up to the 3rd brake light. Need to figure out which wiring
Deelock
