MeanoTorino
I have win 7 64 bit. Is it that much of a PITA to get it to install?
I would imagine you could install it on your 64 bit machine then run the program in compatibility mode. Any one else done this?
Version 12 listed above works great
What version windows do you have? xp, 7 or 10? What version 32 or 64 bit?
I'm looking to give this one more try, but I want to buy the right one.
1. I ordered this one. Received it quickly (few days) and it has worked flawlessly. Mini VCI Diagnostic Tool Cable Scanner for Toyota Lexus TIS Techstream V10.30.29 | eBay
2. The CD has a link to a YouTube video on the install. It's pretty straightforward though. https://www.youtube.com/watch?v=5naojn2BXhs
3. I installed it on Win7 32 bit. 32 bit definitely makes the install much simpler. My brother got it working on his Lexus on a Win10 64 bit laptop but it took a lot more messing around with files/drivers (we both work in IT) if you want to save yourself time/headaches just use XP or Win7 32 bit. I also recommend you do it on a machine that you don't use regularly.
Anyone in the NY area that wants to program my 4r for some beer?
I could not get this to work with my windows 7 32 bit laptop. However.... a friend gave me an old laptop with Windows XP Pro, and it works. Anyone know what I select for my car? I drive a 2014 5th gen.
In the vehicle setup screen, after I choose 4 runner i have the following options
-0908
0908-1008
1008-1208
1208-1308
1308-
i think the ignition needs to be in the on position or maybe even the car needs to be on - and it should be automatic.
Not running, just on.OK, will try with the car running. I had the key in the on position.
Reading thru this thread someone thought that this related to the gens. given he drives a 5th gen like me, he chose the last one on the list and was able to make changes.
I'm hoping someone can confirm, as I'm afraid of screwing something up.
What I'm looking to do is:
- change the TPMS sensor setting. I'm running KO2s at 40 psi. Stock TPMS setting is 32 psi
- turn off the beeps when you lock/unlock doors
- roll down all windows, including rear lift gate, with the key fob. Hopefully sunroof open too
- turn off seat belt chimes
- change the TPMS sensor setting. I'm running KO2s at 40 psi. Stock TPMS setting is 32 psi - i can see the TPMS in the scan area, but not in the Customize area.
Why are you guys trying to change the settings on the TPMS sensors? What problems are ya'll having? It's very important to make sure they are all registered properly to the body ECU.
This process requires the activation of the TPMS sensor using low frequency radio and the capture of the UHF data transmitted. This data includes the TPMS ID, the pressure and temperature.
