Connor, what do yours look like at normal ride height, on level ground? Love those pizza cutters!
No prob. We made them that way for the people running lc shocks or longer so they wouldn't unseat. On one of the 4Runners at the shop, the 890's came unseated at full flex with the shocks that are in it so we wanted to prevent that but not give it a crazy amount of lift.
Always good to hear feedback though! Would anyone be against us bumping the spring rate up?
Rear sits a little high
I actually meant the coil itself, mainly the top portion, to compare to the picture i posted. I want to see what they look like on a lighter rig. Am i making sense?
I see so many clean undercarriages here...![]()
These supercoils look like a great option!![]()
I have the superflex's now, they were definitely better than the 891's. However, now that i've brewed up a custom rear bumper and tire carrier which now holds my 33" spare, it sits level. Not complaining about that, level is better than sag, but I still want some rear rake, I dont even have my coolers in there yet! I'm not sure if 861's would be too much for what I'm trying to accomplish, or if the OME trim packers would suffice....
You could do a little spacer but if you install some air bags and a small compressor you can get your height back and have the ability to go soft or tight depending if your on or offroad.
You would think different if you were at 6000' and drive regularly to over 12,000'.
That is a power loss of 3% per 1000'.
Sealevel HP is 190
6000' HP is ~158
12,000 HP is ~130
I have a quick question. Is there any long travel shock that I could use that would bolt straight onto my 4runner other than the bilstien 5100 ext. I want a shock with a reservoir for when I'm in the desert because my OME shocks fade quick. Any options out there without have to make custom shock mounts?
I can't DIRECTLY compare but a guy I wheeled with had the sonoran lift. Flexed like crazy with his links disconnected and did everything it should have.Is there anyone out there who can directly compare their experience with the LC coils vs the Superflexes?
I'm about to start begging .... Please!
