Toytec ultimate 3" front adjustable lift, any tips, tricks or hints?
Im about to order this suspension to replace the one that came on my vehicle when I purchased it. It's sagging and pretty much shot.
How will I know if I've cranked to 3" if I don't have a stock base to work from?
Talked to Dylan at Toytec
I was dumb, should have measured height before install, Dylan said they ship at about 3" in the front so I'll need to backem off and realign, I'll post the outcome.
Have fun at the Hobby shop! I did mine at Hurlbut Field by myself in about 4 hrs along with mounting and balancing my tires.
Biggest help will be a ratchet strap to compress the front. Rear end is cake. I'm at 30 threads up on my fronts. Then get an alignment. Be really careful no to damage the upper/lower ball joint boots or you'll be looking at new ones.
The ride is great but I have 1.5" spacer (not installed yet) for the rear to compensate for the sag.
I understand everyones measurements are a little different but what were some of your measurements before the lift and after the lift. I have a 2001
kimyuseung77
