Toytec Ultimate assembly
jonb2
Member
Hi All.
Currently have 2wd, V6 with Bilstein 5100 all around, front set at 0.85 lift, top plate spacer and stock coils. Thinking about upgrading to Toytec Ultimate kit so called them but got conflicting answers to some questions:
1. How does the coilover come assembled? With 5100 height clip on bottom, 2nd notch?
2. The Ultimate uses a thicker top plate as well. Does that function more like a coil spacer or top spacer?
3. How does the on road, street ride compare to just the Bilstein only/stock coil setup for those who upgraded to the Ultimate?
thanks!
Hi All.
thanks!
Ultimate is a threaded body, Toytec threads it instead of the clip rings on the standard 5100. Toytec can preset it to any height you want and you can adjust it once it's on the vehicle without removing the assembly.
tuṣṭāva
