Toytec Ultimate Lift - UCA Replacement?
Grape Ape
Member
Ok, so back and forth we go. My lift is here, but as I review posts from all over it seems as though there is no real answer to the question.
For those who have installed a Toytec Ultimate on a TE with KDSS, what are your reasons for staying OEM or going aftermarket. Any real world data to support your case is appreciated.
Current plan is to lift and add 285/70/17s
I have no data at all, I just replaced them, no issues either
I have camburgs and I may swap them out to the the LR-UCA, they are much cooler.
Go for aftermarket UCAs .. you'll be able to dial-in much better front alignment (specifically caster angle) and not have issues with your 285s rubbing on the body mounts. You'll also gain a bit more clearance between the tire sidewall and the UCA.
Thanks for the input. I'll probably end up replacing them. Lift is going in first and I'll keep sporting the TE rims with BFG ATs 265s right now until they wear out.
Kaliram
