Tpms
ZombH8R
So I had all my TPMS replaced 2 weeks ago, well today the light started flashing again indicating that something is wrong again. Any ideas?
Did you check your spare? Have you had a change of temps there? That's usually it. I got tired of it so did the disable and removed the TPMS from my wheels. I could have given you a good deal on a set but didn't think of posting them here.
yea the temp dropped down to about 35 last night. I think I am just gonna do the bypass and be done with them.
I killed the stupid system, the "bypass" if you will. No regrets, that was a great mod!
Yea I did the bypass. Bye bye light
I thought I saw some guys jumping the pink/black wire only to an additional ground source, but it looks like you jumped your pink/black wire to the white/black wire. Are these the same processes... or is the pink/black to white/black an easier source for ground?
I've been running some 16" Pro Comp's for about 2 months (without the TPMS sensors) - and I've had zero issues with the idiot light - but some light off roading last weekend must have triggered something, because the light has been blinking ever since.
Appreciate your feedback!
pink/black to white/black is what I did and it has worked. no problems with it.
That's all I needed to read... it works and you're not having any problems. I'm heading out to the garage to take care of mine right now.
Hey, do you have a quick fix (mod) for turning off the TRAC when your center diff isn't engaged? I absolutely hate that I can't get out of my own way when the tires start to spin on some wet pavement.
Thanks Zomb!
Thanks Zomb!
yea I haven't had any problems since doing the mod. I don't know about the TRAC mod.
