Trac Bar
WOW I have been mis-quoted here.
1: Aftermarket control arms can be aligned, the exposed balls will fill with crud in areas with snow/salt and accelerate wear. I have never said aftermarket a-arms could not be aligned. I may have said they are most beneficial on a Pre-Runner not a 4X4 as the CV axles limit any added droop they could add. I may have also said that they are not necessary on a 4X4, as that is my belief, the stock a-arms work fine.
2: The person in SC with the issue I am looking you up and will give you a call, something is probably not installed correctly. Please call me if you have issues.
3: Drop Bracket, the reason I no longer make the part I invented is that "Jeff the Marmot" argued to the death in 2001 that the correct way to correct to do this is to raise the axle side not lower the frame side. When you lower the frame side you change the roll center of the vehicle (look it up on Pirate4x4, they explain it very well) and make the vehicle less stable. I am sure there is an army of you running around with drop brackets that have no issues and you will tell me how amazing your truck is, but it is immoral to sell something that you know produces a negative effect. The problem with the panhard bar is not it's length but the with the restrictive bushings Toyota used. They severely limit articulation. When Lil Skip came out with his gas tank skid he had to redesign it because he did not realize how much more articulation our kits provide. He has re-designed his product to work with our kits and I recommend him to every single customer now. When companies work together better products are made and everyone benefits. The gas tank drive shaft issue is 100% shocks length, it has nothing to do with the length of the panhard bar or where it is bolted. If the shock is too long the drive shaft hits the tank, too short you have limited movement like stock shocks. So you find the longest you can make the shocks for max articulation and not have the shaft hit the tank. This is all with a stock skid as a benchmark, if you go out and destroy your stock skid/tank and it moves then it will hit more and sooner.
4: The adjustable bar is for the free moving bushings. Heims are illegal on the street and wear out quickly. If you want to put your vehicle back to stock you can remove it and there is no welding required. Yes the best idea is to cut all the stock stuff off and build a real high articulation linked suspension. Who would not agree to that.
5: OME front shocks, Andy Pipken at the SE4RJ on slick rock at Tellico blew 2 CV from excess droop in front of a crown, I blew one CV from excesses droop on rocker knocker, Pritchett, Moab. If the front IFS goes down too far the CV binds and the center cage cracks, you get an extremely un-impressive break. A cage cracking is not like some guy on Pirate blowing up a birfield, it is simply that you bound the joint and it cracked and fell apart.
If you have any questions feel free to call me. Please don't believe the 3rd hand quotes from me. I have every intention to sell the beast parts I possibly can and treat people as I would like to be treated. If anyone has any issues with anything we sell, please call me and I will make it right.
Steve Schaefer
Sonoran Steel Fabrication
Steve. I want to apologize for steppin on ur toes man. I know this is how you make a livin. im calling you in a few at lunch. i installed to exact specs included w kit by the way. . .
Steve- I want to say I am very happy with your 1.2 rear system and it works great off-road. However I did not mis-quote you when you said aftermarket arms wont align properly and here is from your own site. I still refer people to your business as you do provide good knowledge and products. I just feel some of it is biased based on my own interactions.
Shaved Stock Upper A-Arm
$500.00
(1996 to 2002) 4Runner
(1995.5 to 2004) Tacoma
If you want to run 315/75/16 tires on your truck, the tires are too wide with 4.5" backspaced rims. Here are your options, 3.5" back spaced rims which will stick out silly far, Southern California high speed arms (forget about ever getting the thing aligned again) or the shaved stock arms which provide you all the clearance and strength as well as all the factory adjust-ability. Your alignment guy can actually adjust the back cams out, the front cams in and still have enough adjustment to hit the caster and camber. This greatly reduces frame rubbing. Something the high speed arms can not do, since they run fully maxed out. Also you will retain the sealed factory ball joint and pressed in a-arm bushings. No squeaking or coming loose.
That was from my experience with ATS in the year 2002. They are no longer in business and the arms they sold had a lot of issues. It is time I update my website from 2002 Data to current data. At the time that was written Total Chaos and Camburg were not even making them yet. I know that TC and Camburg have a very good product. I personally don't like the exposed ball, I would rather have an enclosed joint. This is from my experience with Rubicon Express joints filling with crud and wearing out quickly.
I have updated my site to reflect 2011 data and have removed the error you have pointed out. Thanks for the help.
It now reads as follows:
If you want to run 315/75/16 tires on your truck with a stock 4.5" backspaced 16"x8" or 16"x7" wheel these give you the clearance. The other option is to get a 3.5" backspaced 16"x8" wheel and you will not need these upper a-arms. If you have questions call and we can advise you on your specific build.
Unfortunately there is still some things on our website that were written in 2001-2002 and so much has changed since then. If you see anything else let me know and I will update it.
FWIW I really like the Light Racing adjustable a-arms, those would be my personal favorite since you have so much adjust ability.
Steve Schaefer
What shock do you recommend to get the 3" lift but not have the drive shaft issues?
We machine a custom Bilstein one here at our shop it is 3.5" longer than stock. Old Man Emu shocks are 1" longer than stock and you will not get the drive shaft issue with them. You will not get the articulation of the shocks we modify, but you will not have the issue either.
I don't have a recommendation for you for an off the shelf 3" over stock shock other than the kits we make.
freddygino
