Tranny Coolers!! Post them if you got them!!
Brian32
after reading alot about the milkshake..im gonna install on..jw if anyone who has one installed could post a pic of how they mounted it and which one you went with..im just trying to figure out which one would be good for me dont know much about them...i dont do any offroading and i live in cleveland i dont know if offroading or cold weather matters when it comes to chosing one but any info would be great thanks!
Hmmmmm.... I think you need to do some searching. This has been covered lots of times and lots of info is already out there.
Personally, I prefer a new Koyo radiator as milkshake prevention.
1. you get a new radiator on an old truck
2. less connections/hose to leak/fail
They may be a resonable option for rock crawling in the desert at slow speed or if you tow stuff.
just my .02
just my .02
alot more expensive tho
i think i got one or two on my rig, along with an external filter maybe... cant remember though, go look through my build thread, it might be in there
Your talking $117 vs $55 from amazon.
I have on brand new never used for $45 shipped. PM me if interested. Going to go full radiator route.
I am running a Trucool 4544 transmission cooler. The transmission cooler has the same number of fittings as stock when you completely bypass the original.
just my .02
I prefer a new Koyo radiator as milkshake prevention. - Disagree, new parts can and do fail. While it's reasonable to expect a new radiator to not fail, you still run the risk of the milkshake.
1. you get a new radiator on an old truck-true, and even if you run an external cooler, let's not forget that the radiators main function is to cool the engine, not the trans. Good idea to replace with age.
2. less connections/hose to leak/fail-again, disagree. No more fittings than running it to the radiator. It's the same set up from the trans to the cooler as it is from the trans to the radiator.
THE ONLY GUARANTEE you can have for preventing the milkshake is to run an external cooler and bypass the one in the radiator. If you have you trans running into the radiator, you ALWAYS run the risk of the milkshake.
or you can get a trd cooler and it gives you an extra 20hp :D
I have a trd one, not installed yet, but I got a good deal on it which is why I bought it. Need to install it soon though, summer is right around the corner.
B&m 20768
I find it easier to just to perform proper car maintenance.
My radiator wasn't replace when I bought the vehicle at 180k. 80k overdue for a radiator, radiator was the 1st thing I bought.
Easier, sure. But it doesn't guarantee you won't have the milkshake. The only guarantee you'll have is to sperate them.
B&M 70274
These aren't the best pics, but this is where I mounted mine, behind the lower plastic bumper valence.
P1010033.jpg~original
P1010085-1-1.jpg~original
Probably should have mounted it closer to the condenser, but oh well. The cooler is kinda big but the weather in Hawaii is pretty warm for the most part, at least compared to the mainland that is.
thats what im having trouble with.... deciding on which one would be best for me...i dont do any towing or offroading....its just a dd
Well, I say too big for just a dd, but no one knows the actual BTU rating of the OE cooler. So when buying an auxillary cooler, all you do is guess wether or not it will be undersized, adequate or overkill. All any of us can do is report on how their cooler works, in their climate with their driving habits. The only actual recommendation for aux coolers I have ever seen was from B&M. They say if you are using JUST the aux cooler and NOT in conjuction with a radiators cooler, to use the one I have. That being said, I dont think anyone has reported ill effects with the smaller ones in normal driving conditions.
