Tranny Help
Polerdogg
i got a 92 and for some reason, after sitting for several months it wont go in reverse nor neutral , it drives ok, and it tends to put out a lot of heat, can feel it while driving :wtf:
:fishing:
:fishing:
The politically correct terminology these days is transgender, as in “Caitlyn Jenner, a transgender person, just won an ESPY Arthur Ash Courage Award instead of Lauren Hill who died of brain cancer at 19 years of age.”
Now back to your topic, it sounds like a transmission problem I’ve had with seals on the pump going bad/drying out, then the pump doesn’t work as well. Believe it or not, I’ve “fixed” bad shifts and seal problems with Lucas Transmission fix. Sounds like you need to start saving for a rebuild.
