Re: Re. tranny life
:bash:
SLED said:There's more info about tranny life at:
http://en.wikipedia.org/wiki/Transvestite
:bash:
hammersc said:I've always gone easy on the motor unless in an emergency. So my 4runner probably thinks I'm a shrivled up old blue-haired lady that can't see over the wheel. I just had my 60k mi. full service done - I'll check my book after work to see if that trans service was included. Prob not I would imagine.
triguy74 said:ah man....i thought we were going to see pics of you in panty hose and high heels. how disappointing!!! :biggrin2:
Bacon said:damnit. Tempsho beat me to it. I have a horrible memory, but that sequence of buttons is burned into my brain for life.
back to the question from the original post. I'm fairly certain that I will be the only one who will answer that I've had to replace the five speed in my 4thGen T4R. 68 thousand miles was apparently the bottom of the 'berg for mine. no issues similar to what you're talking about, which have been explained already (the new trans in mine does that now occasionally). Nope, I was stuck in the snow in my driveway, and the tires just stopped spinning. kaput. that was it. I am the third owner, so I figure somebody who had it before was not very nice to it.
hammersc said:Bacon,
How much to replace your tranny? Did you rebuild or replace? Mine is acting all screwy again and today it wouldn't shift past 3rd gear, regardless of speed. Doh!!!!!
wis99ski said:I have a new runner with 3000k miles on it and it has the same "jumpy" rolling stop issues, and let me tell you it is pretty annoying. I had the dealer lube up the slip joint, didnt really do much. But this can not be good for the tranny when it is jumpy like this???????
My buddy is a Toyota/Lexus master mech. He gets lots Toyota and Lexus products with bad transmissions due to Transmission flushes. He does not recomend flushes, only drain and fill. They are very sensitive to fluid levels. I have 135k miles on my 03 T4R with OME suspension and 285 bfg ko's and I've never had a problem. I would do a drain and fill, its very easy in a v6. Make sure you get your fluid from dealer.
