Same except the dial uses servos bolted to where the cover plate would be for the levers on the lever actuated transfer case. You could convert one to the other pretty easy if you had a donor vehicle.
Jetboy we have a very very different understanding of this. I will post links to what I found when I get home tonight, could you please do the same?
As I understand it, the lever-shift model is the VF2AM, and the electronic-shift model is the VF2BM.
Your way sounds way better, hope you are right.
So the transfer cases are basically the same except for the way they engage in the different settings?
And it looks like they are not chain driven.
Yes.
Where did you get that? They are chain driven.
Also, both models still have a motor driven actuator to engage passenger side CV axle (ADD). It seems pretty reliable, but I have seen one fail to function and leave an FJ SOL.
A sliding collar, just to the right of the front diff, which disconnects the passenger side axle. With the passenger side axle disconnected, only the side gears in the diff turn. R&P and front drive shaft don't turn, improving fuel economy, (slightly) less wear, etc.What is this?
I have seen "ADD" referenced in a few threads but didn't know what it means.
Yep, had the ADD fail on my old Tacoma during a snowstorm lol when I tried to shift into 4WD with my manual transfer case lever. :eyebrows: Right at around 60,000 miles on the odo.
The ADD actuator had to be replaced...
So you could still move just not in 4WD?
^^^ what he said. Just think of it as being equivalent to auto-locking hubs. The only issue with it is that if the motor does not actuate and the collar does not slide... no 4wd. The front drive shaft will spin, but the diff will put all the power to the disconnected side.
Point is, manual T-case is not manual 4wd engagement.
Thanks for the explanation. Got it.
Doesn't seem like it would save that much gas to add a feature that is problematic.
I'm trying to decide between new SR5 and a Trail. Don't really need the TE as you can see in my avatar, but I'm not a fan of the transfer case dial in the SR5 and would prefer the lever for obvious reasons.
So I'm thinking I probably wouldn't use the 4WD a bunch unless I park the Burb and only use that for the extreme stuff, which is rare, and use the 4runner more.
I was eyeballing the new '16 Tacoma but I don't think I want to Beta test it. I've had some minor problems with my RAV4 due to first year stuff, love it, but based on that I would rather get the 4Runner because it's been out for a few years now. Plus I told my wife 20 years ago when I had my pickup I was going to get a 4Runner.
