Transmission Drain/Fill Plugs and Gaskets
DMX512
I am getting ready to do the Diff & TCase fluid change and want to tackle the Trans in a week or two. This thread was very informative and helpful regarding part #'s etc... http://www.toyota-4runner.org/maint...ntial-transfer-case-fluids-pics-included.html
Does anyone have the part #'s for the drain/fill/overflow plugs and gaskets?
Partznet's diagrams are not the best sometimes and I don't think I am calling the parts the same thing Toyota does.
Thanks in advance
I just did this last week. I bought the main pan plug and the overfill plug ( I was scared to death I'd strip the hex out) what I can tell you is they share the same crush washer/gasket part number. If I can find my invoice I'll pass the part number on to you
[MENTION=136099]Ratubbs[/MENTION]
If you could find those part #'s that would be a great help.
I will continue noodling around the ole interwebs.
[MENTION=128090]shahsmerdis[/MENTION]
Thanks for the link but, I have ordered all of the diff/t case plugs and extra gaskets already.
Here ya go. Just did a drain/refill this last weekend and added shudder fix as mine was shuddering. 191,xxx miles on my tranny.
Transmission Drain/Overflow Plug Gasket Toyota # 35178-30010
Sent from my LG-K371 using Tapatalk
WARNING , semi hijack coming...
How did the shudder fix work out for you? How many miles since the treatment and what have been the results ?
TIA
Didnt notice a change until about 150 miles. Shudder is gone...keeping fingers crossed.
ATF drain & overflow - 35178-30010
transfer case fill & drains - 90430-A0003
front diff drain - 90430-24003
front diff fill - 12157-10010
rear diff fill & drains - 12157-10010
There are 3 bolts. Drain, Overflow, and Fill. I think the fill bolt uses an O-ring that you don't have to replace, but I can't remember. The drain and overflow bolts use the same crush washer.
[MENTION=113611]m85476585[/MENTION]
I was hoping that someone knew the part numbers for all 3 plugs and gaskets.
I guess I will go to a dealership and try to deal with them giving me the #'s probably while telling me it is a sealed trans, blah,blah,blah.
I looked at some diagrams with the parts guy at the dealership, and we couldn't figure out the one for the fill plug. The normal parts guy wasn't there, but he probably has it memorized. It didn't seem to need to be replaced, anyway.
I agree that the plugs probably do not need to be replaced, but.
I am getting ready to do the t-case and diff fluid changes and I bought all new plugs just for piece of mind as well as multiple gaskets for each to have on hand for future fluid changes. It sucks having to postpone a relatively easy project because of a $3 part.
come to think of it, when I did my diffs last weekend I noticed (i think the transfer case) drain plug was not magnetic. Is this the case? or did someone previous install the wrong plug?
Laredotx
