TRD 1.3 bar radiator cap
It may help a little bit but may not, enough for the long haul. If I was you, I would look(Longevity wise of course) into an aftermarket Rad.
I had one on my TRD Taco.. The radiator cap that is :biggrin1:
Cooling system is in good condition right now. My temps are always good (monitored on ultra gauge) I just want sure if allowing a higher pressure ie higher boing point in the system (pressure adjusted) would be worth the $40 for the cap.
I don't think it would change temps, only raise the boiling point of the coolant. You would still be putting the same amount of heat into the coolant and still be removing the heat at the same rate via the radiator and fan.
Jhunt
