TRD 17" Gloss Gunmetal Gray Wheel - Anyone running them?
westwind77
I'm curious if anyone here is running the TRD 17" Gloss Gunmetal Gray Wheels they have as an 'option' on their site (only with certain models though):
I would really like to see how it looks on the White or Silver 4R.
It says it has a greater offset, any issues with that - rubbing or allowing it to extend past the fender and kicking rocks to the side of the vehicle, etc?
Interesting....I guess either they are very new to the market or people here are running non-Toyota aftermarket wheels.
Don’t often see them in gloss gray. Lots of matte gray though.
I ran them with 1.25 inch spacers, so with the lift, i still needed a body mount chop with 285s. If I took the spacers off, they would clear much better though (I don't think they would rub at all), I just really liked the stance with the spacers. They are the exactly the same specs as the regular trd pro wheels. 17x7 +4 offset.
That sits perfect. I want to run spacers but many places are saying they can be dangerous. Not sure what to believe on the interweb. I have a white ORP and want to get black TRDs but those gunmetal look killer. Are those Wildpeaks?
Spacers are only really dangerous if you don't install them correctly and or recheck them after you install them occasionally. I ran them for 60k miles, which included a good amount of off-roading, and I had zero issues. Using the supplied loctite is key. I also recommend getting a reputable brand like Spidertrax that is hub centric.
Keep in mind though, with trd wheels and wheel spacers, you will definitely rub if you plan to run 285s. I needed a body mount chop for this set-up.
Those are Cooper Stt Pro's btw (285/70/17)
