Trd off road to SR5 struts
CalicoSR5
Afternoon!
Picked up a set of 2018 shocks and struts from a trd off road. Is this plug n play on a 2014 sr5 4x4? The front coils seem to be the same height at about 14" on both.
Ha! Whys that? I am at 100k miles and just wanted a replacement. Got em for $100 for front struts and rear shocks
Not a pro. Just a trd off road. I noticed both springs are the same height though. I thought the fronts on 4runner had a larger spring on the driver side to make up for weight?
No my OR had the lean before the lift. So stockers don't compensate for anything.
But if just looking for a stock replacement you are fine.
Isn't it the exact same shock and spring on both?
I would even bother doing the job or spending the money to do it unless you actually had a blown shock.
I thought it was exactly the same as well. Just the Pro was different.
Which is why I was hoping he didn't pay since its not really an upgrade.
The only two options that come with different shocks are the Pro and Limited with XREAS.
Pro comes with an off-road performance shock.
Limited comes with Linked shocks that basically act like a sway bar.
The other trim levels are identical.
TireSizeDB
