TRD04RUNNER
OK I'm going to do everyone a favorer and cut/open one up with my heck saw! where do I cut??:behead:
Threxx said:Thanks for doing that, man. That will really help us know what we're comparing here.
I'm not saying there's anything wrong with the TRD, but honestly I'm more impressed by the OEM filter. The synthetic organic filtering media is some really cool stuff that you don't even get from such quality filters as Mobil 1 or apparently the TRD.
After looking at that filter I would have to figure this
-If you drive hard (thus having a use for the extra flow capacity) or would like to extend your oil change intervals, I could see an advantage with the TRD.
-But if you just want to maintain the upmost protection of your engine, without having a need to depend on any extra oil flow (outside of manufacturer specs such as would be required with a supercharger, etc), the OEM filter is my choice.
TRD04RUNNER said:Threxx if you are talking about the stock Toyota filter that was cut open in those post like the 20004 and yzzB5 those are made in japan and you can't get them at the dealer. I don't think anyone has cut open up a yzzd3 yet. so it might not look that the 20004 or yzzB5. The new replacement for the 4R is the Yzzd3 and it made in Taiwan..Those you can get at the dealer.
""OHH SNAP!!" I should have cut open that use YZZD3 when i took it out . I trough those other post with the cut out stock filter was the yzzd3. to late now! garbage pick up was Thursday.![]()
Please do not tell me that you're implying you simply threw your motor oil saturated oil filter into the regular garbage. I cringe to think you are suggesting that you sent your oil filter to a land fill so it could leak motor oil into your local water supply! My local hazard waste center takes oil filters along with motor oil.TRD04RUNNER said:I trough those other post with the cut out stock filter was the yzzd3. to late now! garbage pick up was Thursday.![]()
CMiYC said:Please do not tell me that you're implying you simply threw your motor oil saturated oil filter into the regular garbage. I cringe to think you are suggesting that you sent your oil filter to a land fill so it could leak motor oil into your local water supply! My local hazard waste center takes oil filters along with motor oil.
I just read that the Amsoil filter has a anti-drainback valve like the Toyota filters, but do you know how much pressure the Amsoil filters are rated for?RL Lemke said:Here is a photo of the big TRD filter, another TRD filter that is the same size as stock, and the Amsoil filter.
EDGE said:I found an M1 filter that was twice as long as the OEM Toyota filter, gonna use it on the next change.
Im already putting 7 quarts in, I'll see if I can get 7.5 or 8![]()
