Engineer
Seriously, coefficient of friction of rubber on asphalt is the limiting factor. Stock brakes are fine.
Your post beat my PM, that is what my paragraph of BS was essentially getting at. :clap2:
This is a good mod, a why not, whatever mod, kinda cool mod. Why would it cause controversy? This is not a garbage bag mod. How is it that even a thread with a genuine enthusiast mod such as this turns into poop? <Rhetorical question. I am trying to get used to that fact. (I won't.)
I like the brakes, and, yes, the rears need to match.
That was when Lombard Street was straight!
Because this is the 4Runner forum. It is not a GTR forum. Most enthusiasts on this site are off-road oriented. A few on here are interested in modding the performance aspects of the vehicle. I being one of them.
[MENTION=66316]1engineer[/MENTION] - Sounds like tires are what matter most. But wouldn't larger two piece rotors that are lighter than stock, (to make a point look at carbon ceramic), with less rotational mass feel much more responsive in terms of acceleration, handling and braking? Just as adding larger 33" tires would hinder those aspects of performance?
Yes I made jokes. Probably shouldn't have.
Many people out there think because they read something then it must be true, especially on the internet.
With that said the two most important components on a vehicle are brakes and tires. Let's talk about stopping ability for a bit. I am not really going to talk about the more esoteric aspects of braking systems because hey, this is a 4600 lb top heavy slug of an SUV right? I don't see track days in the 4Runner's future so improving brakes for less fade and unsprung weight reduction really have no bearing here. Looks? Sure, I will give him that. Red calipers look better.
With that said lets look at the stopping ability of the 4Runner or any vehicle for that matter. Basically breaking is dissipation of the vehicle's kinetic energy. How quick you stop depends on:
1. Reaction time
2. Tires
3. Road Surface
4. Braking system
To decrease stopping distance assuming that items 1-3 are the same then you need to modify the breaking system so that, from time of actuation to the tires being on the edge of sliding, you decrease that time.
Right now, especially with the exceptional braking ability of the 4Runner in panic mode, there are very few things you could mod that will decrease that time. I do not know the exact time from initial control actuation to tires at the edge of lockup but it is measured in milliseconds. How do you speed that up? You modify the electronics in the ABS not the caliper.
Now let's examine the other three items. Reaction time is what it is. Some people have quicker reaction times, some don't. Calipers won't help there.
Tires are extremely important if you want to decrease stopping distance. A big soft, sticky tire would shorten stopping distance considerably. Remember that it only took milliseconds for the tire to go from no breaking to edge of skid breaking. Sticky tires will let the vehicle stop quicker because they provide more adhesion to the road.
Road surface is especially important whether it is wet, ice covered or dry. We usually have no control over that though.
Having slotted rotors, ceramic brake components, carbon parts, more pistons in the caliper and other cool mods are more geared towards repetitive slowing of the vehicle, not stopping. In every day use our 4Runner is just like all the other passenger vehicles out there and stopping is the most important thing the brakes do.
If I really wanted to improve the braking performance of the 4Runner I would:
1. Change out all the brake lines to the strongest available and
2. Get the widest, softest, non aggressive tread tire I could afford to run.
These mods would knock a few feet of the 60-0 stopping distance. The mod that would knock the most off the stopping distance? Reaction time. In the real world you take about 1/3 of your stopping distance to react. There's room for improvement there in everyone.
Here's a link if you want to know a bit more about ABS newtonian mechanics - Does ABS shorten stopping distance of a car? - Physics Stack Exchange but at the end of the day I will enthusiastically concede the point that red calipers look cooler but only if all four are red.
I had tundra brakes on my last 4 runner but I kept warping due to driving a canyon with 4000 vertical feet in 8 miles. But the 5 th gen brakes are much bigger. Is anyone having brake problems?
That link has got to be the most confusing explanation of how and why ABS works that I've ever seen - And I think mostly wrong.
My plan was to go all BBK all 4 corners. They do not have any rear to fit 17. If I go 18 all around, I can get all 4 corners with 2 piece rotor.
There's always pros and cons to every mod.
Some pros to upgrading to bigger brake, when you add a lot of weight to the vehicle, heavy front a rear armor bumper, winch, 33in rims/tire, roof rack, 3 inch lift, you slowly lose the factory brakes and they barely work. My brother's Tacoma is like this, he has to stop a whole block a head of time. HAHAHA!
Thanks for the comments, in the end its my vehicle and I can do what ever I like to it because I own it. :clap2:
