TRD PRO LED Fogs
Rainier42
Anyone have the part numbers for the TRD PRO LED Fog lights? Am looking to install them in my 2020. Also, the LEDs used in them do they throw off a yellow light or a white light?
I have them on my rig. I would go out to the glove box and get the number for you but it’s cold out haha. They are white. I used Lamin-x to make them yellow. I’m happy with the light.
Edit: I did go out, but there was no book for them to check part numbers. The window sticker says LD400. Google didn’t tell me much for that.
The OEM LED fog light are MUCH brighter than the OEM halogen fog lights, plus the pattern is much better too, very flat and wide as a fog should be. .
Not really what was asked.
OEM LED's are not in the same ballpark as even the SS3 Sports. (With SS3's being night and day difference.. Pun intended) Upgrade to pro and its even more of a difference.
Skip OEM and go to SS3.
thanks for that.
I have the Toyota-installed LED Fogs, is there any 'step up' that doesn't require the full $200 SS3 'kit'?
in my research its upgrade to the diode dynamics SS3, or some pods, haven't found anything cheaper, and not expecting to I guess. I haven't pulled the trigger on the SS3 yet but getting close, factory suck, and headlights suck, but don't have the balls to retro fit those quite yet.
I want to say nothing of value is in between the Toyota LED Fogs and the SS3 sports. From what I've seen through research, the LED fogs are better than the stock halogen. With the stock halogen, some folks have used the philips led bulb but that doesn't seem ideal as stated by "The Lighting Engineer at The Other Forum".
Hope that helps!
AndiGarage
