TRD Pro Suspension clip setting
AINOMOATACO
Recently put a TRD PRO suspension with cornfed's 2/1.5 setup on my Trail and am now fighting the KDSS lean. I want to bring up the passenger side.
I know the driver side shock clip is set higher. Is the driver side clip just 1 up from the bottom? and the passenger side is on the very bottom clip?
I believe with KDSS u have to have both clips on top to level the lean.
I installed the FJ/PRO kit and read that KDSS should have top clip on both sides, staggered if non KDSS
KDSS trucks need the clips on the same setting.
I am currently sitting 1.5” higher on the drivers side front and rear. I will set the driver side clip down one (same as passenger side) and see how that goes. How far do you guys think it will go down? Will the rear go down also?
Did you fixed the lean by doing this?
AndiGarage
