TRD Pro Suspension
4runnertrdgirl
need to be educated on this factory suspension...
I'm ready to plop down a sizable amount of cash on a front bumper...weighs
about 135lbs without a winch...
I'm sure it will bring the nose down a bit...I'm trying to figure out if I will need to replace the front coil-overs to lift it or is there another option.
Has anyone every remedied this without replacing the front coil overs?
Is there a spacer kit?
thanks
you should post in the 5th gen forum, since your trd pro has a very specific suspension setup.
Most people who add weight to their rigs, just upgrade their springs, but I can't help you with the specifics, b/c I don't own or know what the trd pro suspension specs are.
thanks....
I figured out what I wanna do...Toytec makes a spacer kit to fit the TRD Pro...
I'll probably get that if its needed
I've been reading a lot and research. I've added about 140lbs more to the front end. Just bought the Toytec 2" lift. I was planning to install the whole kit. After the added extra weight, I've decided to just go with the front kit only to level it out. I'll wait to wear out the suspension before I drop the extra money on new tires and set of new suspension. Here's the link to the Pro Suspension thread
http://www.toyota-4runner.org/showthread.php?t=208900
Sent from my SM-G930V using Tapatalk
I get that...I, too, don't want to spend money replacing things that are new...thanks for the input
I can't speak for the lift due to weight, but Love the color of the 4Runner. Did you have it painted, or did they offer them in that color?
