How does the stock Pro compare to the Limited from an on-road handling perspective? How does body roll around turns and nose dive under braking compare?we have both. A limited and a Pro. the limited visually looks closer to the ground due to body skirt and lower bumpers plus the tires are regular all season. On top of that all seats (especially the back ones) are actually lower to the 4R floor compared to the Pro ones. if you check the ground clearance between the Pro and the Limited, the Pro is taller. The Fox suspension/coils combination lifts it at least by 1.25inches in the front... on top of that the seats are higher compared to the Limited. I am 6.1 I actually have to stretch to get into the driver seat compared to the Limited - where both cars seats are to the max top height setting. so yes small things that add up to the higher ride in the Pro. The Off-Road tires also add to this experience of course (they are a bit taller compared to the stock all season tires i the limited)
Ride quality - nothing beats the Pro with Fox at stock height.
Less than an inch front only.
Front AND rear
There is absolutely no difference in suspensions. I checked.
Can you expand on this at all? How are you determining the rear on a TRD Por is lifted compared to other trims?
I did the measurement myself at the Toyota dealership yesterday and saw it with my OWN eyes. You can take a measurement tape to a Toyota dealership and measure TRD PRO vs other trims....you'll know
I measure from the fender to the center hub cap on the SR5, TRD Offroad and TRD PRO.
Consistently the TRD PRO appears to be 1" taller at the rear compare to other model trims.
Measuring from the ground is inaccurate because different tire sizes will affect the height.
Call and ask any Toyota parts/accessories department 80% of them told me TRD PRO is taller front AND rear and the rear spring are different part number.
That's exactly what I was driving at with my question, wanted to make sure the measurements were taken correctly so we can have an apples to apples comparison. Did you also measure a Limited trim to see how it stacks up?
I mean limited isn't even meant for offroading.
[MENTION=438005]szuyung3000[/MENTION],Can you send me the link to where you buy your rigid industry front grill LED light bar?
I'm debating between a '20 TRD pro (I've since sold my '16 GX 460) and a '20 TRD off road.ground clearance matters depending on the of terrain you are on. lower limited doesn't make it any less capable compared to the other trims. you have a locker on the offroad/pro/venture trims so that helps in certain conditions but in most cases casual off-roading is just fine with 4Lo/4Hi/ATRAC combination. this is why i don't get why some people thing that the Limited is not capable of off-roading. all different trims are offered for a reason to meet peoples' different needs after all. SR5 is the only trims I have not owned so I have no experience with it.
anyways to answer your question, the body roll on the pro is slightly more compared to the off-road with KDSS. the nose dive upon breaking on the pro with Fox is definately more compared to the other trims but i don't know why that matters at all. i however love the fox ride... soft yet stiff when it should be
This is the most ridiculous statement I have heard about the Limited all year. Well done.
While there are differences in the factory trims, all the models can hold their own just fine off-road.
