TRD Pro with 6112 coils (pics inside)
speedyglx
Today got 6112 coils put on my TRD Pro. This is what I got
Stock photos before the coil swap
After coil swap
Received 2 inches of lift in the front from the coils over a stock trd pro. The back coils are wheeler t13. I did not expect to receive that much of a lift but it drives really smooth.
Did you replace the UCA or any other parts?
I am thinking of doing a 6112 lift so thanks for the information.
It looks good. Had you considered the toytec trd pro lift to use the stock trd pro suspension and get 2 additional inches front and back.
After coil swap
Nice! Where did you get the 6112 coils, and did happen to compare them to the stock TRD Pro coils, length wise?
I did not. At least not at this time.
I have considered them but I am not a big fan of spacers. I wanted to try something different.
I bought them from a person on this forum. He swapped his for heavier load coils. As far as the size, they were a 1inch longer than the stock trd pro ones (14inches) Also, I believe the stock trd pro coil have a load of 520 lbs, 6112 coils have a load of 600 lbs.
What clip setting do you have the 6112 at? Did you keep the OEM shock in the rear and just do the t13?
No clip setting. The shocks are from a TRD Pro. They have no clip settings like the 6112 shocks. The rears I kept stock. Same as the front, just replaced the coil.
Measurements
Hey nice setup, I’m going this route. Do you mind posting the measurements from ground to fender and hub to fender?
I actually took some pictures of the measurements this morning from ground to fender. Dead even from front to back. I did not expect that.
Front pic
Rear pic
MMJR_T4R
