Treatment of Surface Body Rust Help
TiN
Hey everyone, my recently purchased 2004 SR5's body is in really good condition for the most part. The only problem is that there is a sizable dent and a few small chips in the paint on the driver's side front pillar (apparently from a falling basketball goal). This problem was left untreated by the previous owner, so a small amount of rust has gathered on the exposed metal. After taking it to a few local shops and getting the same estimate on the cost to pull the dent/fix the paint, I decided that I didn't want to spend that kind of money on a dent right now. Do guys have any suggestions on products that can treat and cover the exposed metal until I am willing to have it professionally fixed? Or should I just go ahead and get all the work done right away?
Thanks for the help!
If you guys want pictures, I'll gladly post some tomorrow when there's some light.
Okay, I'll defer to those that know more than me but I think it matches fine w/o CC though I do wax thoroughly.
[MENTION=50591]gaterose[/MENTION] will know
I don't know anything about personal waxing man, not sure why you mentioned me. I believe it's garden, let it grow..
...Oh crap you meant the clear coat... I use clear coat on the satoshis but I think it may change the color slightly. My grille is clear coated with their clear if you want to look at recent build pics to see how it matches.
edit- The lower bumper centers are sprayed with duplicolor 'color-match' and the duplicolor clear coat. You can see that it's kinda brown/yellow compared to the rest of the bumper.
Show us your dent! Regular Bondo should not be put on any thicker than a dime or it will eventually crack. You could consider Bondo glass for the deepest part and then a thin sandable layer of Bondo on top. It would be best to bump out the dent as much as possible to keep the filler thin. I got matched paint from PaintScratch.com for about $25 a can a couple of years ago. Toyota white doesn't need a clear coat.
Alright, thanks for the suggestions guys! I'll get a few pictures up in a little while so you can see what I'm talking about.
Pictures:
IMAG0130_zps4683da51.jpg~original
IMAG0129_zps8ca3e0e4.jpg~original
IMAG0128_zps61d7887b.jpg~original
Jhunt
