TREK 300 in past 14 years
Ron4RNevada
160407 – A Different Way to Rawhide – Trek 300 – April 7 2016
How about that: the 300th documented trek since I started this back in August of 2002. Lots of memories; three trucks and a bunch of knowledge gained exploring mostly north-western Nevada, a bit of northern California and a smattering of Idaho, Utah and Arizona. This trek is to places that I have been before but taking a much different route to get there.
I left at approximately 9:00am from Fernley; stopped briefly to top up at Harmon Junction (just past Fallon; and then on to Salt Wells. At Salt Well I turned off the highway and headed across Eightmile Flat towards the Cocoon Mountains. Once on the bench on the far side I turn east on the old Pony Express Trail and followed along the “beach line” between Fourmile Flat and the mountain. The track was really crappy!
The track was sand that was firm due to our recent snow on Monday but the wheel ruts were generally deeper than the ten inch clearance under the Toyota chassis plus there were a lot of rocks jutting out. I spent most of the time in Low Range and First Gear trying to keep the tires up on one of the rut banks and the center bank while not hitting the pointy rocks. Across this are I was averaging 9 miles per gallon = a new low. After about fifteen miles of this I finally reached Wightmans Well. A local rancher was pumping water into an old tank truck to go around and fill cattle water tanks.
From Wightmans Well I turned south on a much better road going up Fourmile Canyon. My original plan was to visit the Red Ant Mines but I changed my mind and decided to explore the canyon all the way to the top and go on towards Rawhide. I stopped at the summit to reconnoiter. While sitting there an older gent about my age in a 1962 International Scout came across a ridge and we compared notes. After he headed back towards Sand Mountain I continued on towards Rawhide.
Perhaps two miles past the summit I decided to check out an un-named canyon headed east into the Sand Springs Range for perhaps two and a half miles. The track is basically just the bottom of the wash; mostly gravel and small cobbles with an occasional large rock sticking out. At several points crossing dry falls was required. These falls were where the aplite (a variety of fine grained orthoclase and quartz granite) formations crossed the wash. Without a spotter I had to get out and plan a line; get back in and drive the front wheels onto the rock; get back in and plan the line again to make sure the rear wheels were correct; get back in and finish the crossing.
After about two miles the canyon forked, the right one came to a four foot high rock fall that could possibly be crossed by a rig with about 16 inches of clearance, steep fore and aft approach angles and some steel at the lower extremities; definitely not a stock 2013 4Runner. I took the left fork and got another half mile. Other than some great scenery the canyon had a couple of prospects and one mine tunnel that I didn’t venture more than a few yards into. Returning down canyon the rock falls were much easier to navigate. The high point in the canyon for me was at 6143 feet. Once back on the main track I continued south towards Rawhide.
As I met the road that runs from Rawhide to the Walker River Paiute Reservation I spotted a lot of old mining activity on the slopes of the Agai Pah Hills and Ghost Dance Ridge. This mining area was called Regent. This was a silver and gold mining area. The hills are quite chewed up with roads mine shafts and tailings piles.
After leaving Regent I took the well graded road south east thru the present day site of Rawhide and the National Mill. The old town and all signs of the original Gold mines are gone. Now the Nevada Scheelite Company has been strip mining several square miles of the area taking out tungsten ore (scheelite).
After leaving Rawhide I turned north on the highway 831 through Fairview valley and the gunnery/bombing range to highway 50 and then west back to Fallon and Fernley.
30002-Corral%20Four%20Mile%20Flat_zpsvw9lovxh.jpg~original
Corral between Fourmile Flat and Cocoon Mountain
30003-Four%20Mile%20Flat%20and%20Sand%20Mountain_zps0iqbv3gj.jpg~original
Sand Mountain across flat
30004-Sand_zpsax9srvlx.jpg~original
30005-Pony%20Express%20Sign_zpsts1ryjyt.jpg~original
30007-Sand%20Mt_zpsqgg5ll6v.jpg~original
a mile long 700 feet high
30009-Cocoon%20Mts_zpszcvczdjx.jpg~original
30011-Rock%20and%20Sand_zpsmdulnb9a.jpg~original
rock and sand and rock and sand and - - - -
30015-Adit%20in%20Aplite_zpsydwjkyq7.jpg~original
an adit in the aplite
30016-In%20front%20of%20adit_zpsdvrro1rb.jpg~original
30020-Doing%20Own%20Spotting_zps2lysurkb.jpg~original
when you do your own spotting
30022-In%20a%20modded%20Rubicon%20-%20Maybe_zpsx3fvuhha.jpg~original
I probably could have done it in my old LR Discovery - better approach angles - better clearance - everything tucked five inches above the eleven inch frame height - no plastic body parts like the T4R
30024-It%20just%20gets%20worse_zpspbydsubz.jpg~original
30025-Thankful%20for%20E%20rated%20LTs_zpsmksijatw.jpg~original
E rated tires help a lot
30026-Solitude_zpsrnnznycr.jpg~original
Ahhh - solitude -
30029-Mine%20shaft_zpsd3wxixjs.jpg~original
Mines at Regent site
30032-Regents_zps5vm1ksja.jpg~original
30033-Regents_zpsi1sji203.jpg~original
30035-NV%20Scheelite%20Mine_zps6y6fi5x8.jpg~original
NV Scheelite workings
30036-NV%20Scheelite-Rawhide_zpsdcdmzydn.jpg~original
30039-So%20much%20free%20space_zpsbasjchpa.jpg~original
[MENTION=118209]Ron4RNevada[/MENTION] We're looking at coming up there soon to try and run the Pony Express trail all the way from the Utah border to Lake Tahoe. Was most of your trip on the PX?
You by chance have GPS tracks of your route? Just want to compare it to the route we have planned out.
I was only on the Pony Express track for about 15 miles the other day. I've traveled probably 150 miles total of the track in western Nevada. No I haven't kept data accuratly of my routes..
You can find sites that will give you routes of the Pony Express and Overland Stage (Mostly along the same route). A fellow named Simpson laid out most of the route.
A source:
"A Route for the Overland Stage" Jesse g. Petersen 2008
available on Amazon for $26.95
Simpson surveyed the trail in 1859 that was later used by stage lines, freight lines and the Pony Express. Eventually the Lincoln Highway followed much of the Route.
Nice. You've got me by about 50 but I've only been at it since 2005 so in some sense I'm keepin' up.
Your report was data porridge served at just the right temperature. Just enough info to allow me to discover and trace the route on maps (no Google Earth allowed, too much like shooting fish in a barrel), which I find a very pleasurable exercise. Next best thing to being behind the wheel.
Thank you. Back in the old days it was about how much you could challenge the truck - These days it's mostly about exploring -> When I pass a canyon on one trek I keep it in mind for exploring on the next trek. I've been just about everywhere here in northern Nevada -> now it's about filling in the blanks.
Ron, I enjoy reading about your wanderings in my old backyard. Used to camp in the Rawhide jail, and my dad fell about 60' into one of the nearby shafts (back in the 70s)-nothing broken, but bruised everywhere. I was there a few years ago, but Rawhide is simply gone. It ruins good memories, so I'll not be going back. Used to often drive from around Ft. Churchill to Rawhide, down to Hawthorne & up to Masonic and Bodie. Keep up the great trip reports!
awesome...it's nice to read that your doing this with a stock vehicle (other than tires that is)!
What most people here DO NOT realize is stock is more than capable for most real life situations.
If I am in the real world (not some OHV park) and I want to get from point "A" to point "B" on a trail or dirt road then there are multiple routes or at least "bypasses" I can take and still get to "B". Yes, it's still just as fun. I always take the easiest bypasses I can find. As a matter of fact most could be done by a Subaru or the like. To the stock (different tires though) 4Runner it's no sweat and the likelihood of me bending stuff goes down greatly. If anyone tells you you HAVE to modify a 4Runner to take it off road that's a dead giveaway he knows nothing about what he is talking about. If you are going to spend your time in an OHV park or just doing obstacles then modding it is the way to go. Otherwise? Leave it stock and have fun. Ron has shown it to be no problem and I appreciate his trip reports.
On the track through the alkaline sand I did have to move a couple of rocks away from the crown between the wheel ruts that were more than ten inches tall' In the canyon with the spiky aplite bedrock teeth sticking up it was a bit difficult finding the right high spots for placing the tires and clearing the centerline of the truck.
The best advice - is to walk it first; then to be in Low Range and First Gear.
"As slow as possible, as fast as necessary" Do not try for "bumping" up the rocks face - with the right tires and LO-1st it will climb.
The biggest handicap on my truck is the step on the right side of my truck that I installed for my short wife to climb in with - I drag that a lot.
I just received my own copy of
"A ROUTE FOR THE OVERLAND STAGE"
James AH Simpson's 1859 Trail Across the Great Basin"
by Jesse G. Petersen 2008
A very well done publication. Mr Petersen spent eight years researching and driving the whole trail. the book contains hand drawn maps of each days journey by Simpson; also present day photographs of each campsite location. There is an appendix that lists the geographic coordinates for each campsite and station.
Very well worth the $26 from Amazon.
Of the 564 miles from Camp Floyd, Utah to Genoa Nevada it appears that I've driven approximately half of it. I guess I'd better get started on completing it.
Gotta love all these historic trails around Nevada. The history around here is enough to entice me to start wandering every chance I get. :)
I just finished plotting the trail across Nevada on an old Delorme Nevada Atlas. Looks like I've done the whole trail except for the last 50 miles from the Utah border......
Thats the westerly trail surveyed by Simposon - there are a few changes when he plotted the trail back.
charlesz
