Triangle exclamation light and beep at start up
ASUMTNEER
Is it normal to have the yellow triangular exclamation light illuminate and beep for a second or 2 on start up? There is no text under the light pointing to a specific issue.
My wife's RAV4 did that (the beep, anyway - didn't look for the light) and it was because the sunroof wasn't fully closed.
If the rear hatch is closed but not fully seated in the latch , it will cause the light (yellow triangle) and beep you describe. Just re-close the hatch and it should go away. Passenger doors that are not fully closed cause the "door ajar" icon (red) to appear .
if you don't have an owners manual to read there is this new thing out called the internet in which you can look things up and it actually will give you answers to all your questions. its amazing! the warning light is a master warning light.
What's this internet you speak of...?
It has to be a door not latching properly
Sent from my SM-N960U using Tapatalk
I have the same problem. Can you help me? There is an exclamation mark inside a triangle. It is yellow.
lilianmarais
