Trouble removing bumper shell on '07
ddnww
Front bumper
I found some threads on how to remove bumper, seems pretty straight forward. Even downloaded a diagram someone posted. However I am having trouble getting the shell off. Im sure the actual metal bumper is no problem , looks like just some heavy duty bolts.
I removed I believe 4 pop tabs or whatever they are called on top of shell, and I think 5 bolts on bottom, and 2 screws each side under fender flare. I got the bottom free , but where the top of the shell meets the fender flare right near the head lights, I cannot get that loose. Im not sure if theres another bolt im not seeing or what I need to do. :confused:
I need to remove bumper to take to fabricator to measure up for custom bumper.
thanks for any help guys. Im counting on you.:yo:
the sides by the fender once the bolts are removed take a hefty pull away from the fender itself. Its clipped in and it can be tough to pop off the first time.
OK, that's what I was thinking I may need to do, but I didn't want to just pull the heck out of it and mess things up.
