Troubleshooting the driver power window switch
under40daddy
Hi all,
Having a problem with my driver's power window switch. The remote mirror control, central locking, and window lock-out switches all work, but the individual window switches do not work. All windows passenger windows can be operated by their door switches, but not from the drivers switch.
I've tried a new power window switch but the same problem persists.
I've tried to trace out the wiring, and I've confirmed I'm not getting 12V on T10 of the wiring harness as per this wiring diagram. I've tried tracing that wire (blue with red tracer) back to the IF1 junction in the left kick panel, but I can't tell if I'm tracing the correct wire or if I don't have a connection.
I've also tried to jump 12V to T10 on the wiring harness in the door, but that didn't make the switches work.
Any input would be greatly appreciated!
Hi all,
Trace all wires that go through your door Jan under the boot to verify they are all good and
Are not shorting against others. Very common to have some wires break in the door jam and cause issues..:)
Sent from my SM-A505U using Tapatalk
Mike Sargent
