True Wire colors for 06 and Up
jdmgwagon
ACCESSORY
12volts
white/blue (50A), red (30A)
ignition harness
Ignition black/red + ignition harness
Parking Lights+ green + left of fuses, 16 pin plug
Parking Lights- green - BECU, top plug, pin 8
Headlight white - BECU, top plug, pin 20
Trunk/Hatch Release N/A
Power Sliding Door N/A
Speed Sense purple/red ECM, 2nd plug from bottom, pin 8
Wipers blue/black (L), blue/red (H) + windshield wiper switch
Sun Roof open/close motor part of module
Sun Roof Limit/close N/A
Memory Seat 1 pink - memory seat switch on dash
Memory Seat 2 purple - memory seat switch on dash
Memory Seat 3 N/A -
REMOTE START
12volts
ignition harness
Starter green/black + ignition harness
Second Starter N/A
Second Ignition blue/yellow + ignition harness
Third Ignition N/A
Accessory white/green + ignition harness
Second Accessory N/A
Keysense green/yellow - ign harn or BECU, top plug, pin 14
Power Lock blue - driver kick, 18 pin plug
Power Unlock green (double pulse) - driver kick, 18 pin plug
Lock Motor blue/red to black/white 5wi driver kick, 13 pin plug
Unlock Motor blue/black to black/red 5wi driver kick, 13 pin plug
Hazards white - hazard switch
Turn Signal(L) blue/black + left of fuses, 16 pin plug
Turn Signal(R) blue/yellow + left of fuses, 16 pin plug
Reverse Light red/yellow + left of fuses, 16 pin plug
Door Trigger purple/yellow - BECU, top plug, pin 12
Dome Supervision white - plug to right of fuses, pin 8
Trunk/Hatch Pin green/yellow - back door ECU in hatch
Hood Pin pink/green - driver kick, blue 18 pin plug
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer black/white ac ECM, 2nd plug from bottom, pin 1
Wait to start N/A
Brake Wire green/yellow + left of fuses, 16 pin plug
Parking Brake lt. green - BECU, middle plug, pin 2
Horn Trigger green/red - horn switch
Memory Seat 3 N/A -
THIS INFO WAS PULLED FROM A DIRECTECH WIRING DIAGRAM
Yeah I installed a Pioneer AVIC-80DVD last night and the VSS and Reverse wire are correct... The rest of it should be completly accurate being that this is what all of the Installers at all of the mobile one locations use around new orleans
DanielShawSZ
