Trying to raise the front an inch
Flyer
I have been noticing that snow/ice gets packed and the front rubs a bit, while it does not normally. I switched the 265/65/17s for 265/70/17s a few years ago and it is an inch taller. Since the tire options suck in the smaller size, I think raising the front an inch will solve the problem. It has a big rake anyway.
I'd rather not use spacers but will if I have to. Why do I not like spacers? Primarily because it stiffens up the ride by compressing the spring even more. May have some CV problems at full droop too.
Currently, I have the FJ TRD's suspension on the 4R, and not the stock setup. If a simple front shock or front spring switch will work, that will be easy enough. I don't want to spend too much since I don't offroad the 4R anymore, though it sees dirt roads, mild trails and lots of snow for skiing, snowshoeing, hiking, etc. I certainly don't need a big lift. I want to maintain drivability and reliability.
Worst case- I go back to the smaller tire size but those tire choices are pretty pathetic so am trying to avoid that.
If you have FJ springs, you are already about an inch taller than a stock 4R. Bigger tires puts you at another half inch. If you still need more but don't want a "lift kit" or spacers, getting Bilstein 5100s and setting it to 0.85 would be the only way I can think of.
The rear went up a bit but the front did not seem to (V8) but the taller tires seem to rub when the fenders and arms are packed with ice/snow. Your adjustable 5100 option may be the best choice.
Bilsteins, definitely. They're pretty cheap, too. It's most likely around the same proportions with the fj susp. as stock.
Great! I'll start looking around for a front set. Then I can put on the DuraTracs and be much more confident in the snow. After 30,000 miles, the Hankook ATM RF10s are starting to lose their grip in the snow.
Looks like all I need are the two shocks and I can reuse the FJ springs. Will see who has them the cheapest (or a local place, I guess) and look for someone with a spring compressor. Getting ~.85" in height increase will be the perfect place to start. The V8 is probably 100 lbs heavier than the V6 so I think they sag a bit more.
So yesterday I drove up north to RCI Metalworks and picked up an aluminum skidplate. I did that primarily to do oil changes without messing with the (warped) skid each time, and a little protection can't hurt. The stock skid is as thin as a spoon.
BillM777
