Tube doors question
loko ino
What do you guys do with all your electricals when you put on the tube doors? Do you cut the cable and add in a connector so you can reconnect everything later? Waht kinda connector did you use? Some sort of molex connect with bullet pins I'm thinking...Or are tube doors for a 4runner with power windows, mirrors and locks just not gonna happen? and
I did search..and saw some stuff..but wanted to see if anyone has experience....
yeh, just get connectors with the correct number of pins. or several connectors, either way.
you'll have to if you want to retain use of those things when you put the doors back on.
Take the kick panel off.
There are two connectors on each side.
Disconnect those, and feed it through the fire wall.
You're all set.
No need to cut wires or anything.
I do this all the time when I put my half doors on.
I'll try to get some pics for you tonight or tomorrow.
I run half doors offroad and in the summer.
I use standard 4 pin trailer lighting connectors to disconnect the wiring on the full doors.
