Tundra brake upgrade question
Will the 13WL caliper up grade clear the factory 5 spoke rim? Or do I have to get wheel spacers?
If this is the wheel you're asking about, you will NOT need spacers:
he said 13WL which is the 231mm Tundra upgrade. those are the wheels i have, and it didn't clear.... i am no guru though, only can speak of personal experience. 13WG will fit under stock wheels with NP, as I understand it
Understood. I had those same wheels when I first did the TBU, and I'm absolutely 100% sure that they do clear the 13WL 231mm calipers. It is also confirmed in post 3 of this thread on the TBU:
http://www.toyota-4runner.org/3rd-gen-t4rs/94923-hard-find-specs-info-measurements-231mm-13wl-tundra-calipers-rotors.html
Not saying I don't believe you - have no idea why your wheels wouldn't clear those brakes when mine did, along with a lot of other folks that have done it.
I withdraw my original post then :) I accept your experience, along with bigfish's thread as the norm.
mine didn't fit by a gnat's a$$ hair, so there is no telling what the variance was. been running fine, so i am not concerned. maybe subconsciously i just wanted spacers :biggrin1:
increasedc
