Turn Signal Blown
Big_Ezzy84
I am having some trouble figuring out what is going on with my turn signal. When I turn my hazards on they work, when I turn my left turn signal on they work, when I turn on my right signal it blinks one time and then nothing works i.e. left turn signal and hazards. I was told from a friend who is a mechanic and has a 97 tacoma that it might be the multifunction switch. Could anyone please give me some incite as to what it could possibly be ?
Combination switch
Did you get this fixed? I had to fix mine when this happened or it wouldn't pass inspection. It buzzed before it stopped working. It's a worn down connection in the combination switch. I took mine apart and built up the worn down part with solder and it worked fine for years.
Check the integration relay. I had the same thing happen and discovered a loose connection in my integration relay.
2001ATL
