Turn signal switch
I have an 89 4Runner and the turn signals switch just gave out and the high beam switch. Is this a part that I can get at auto zone or am I going to have to go on a treasure hunt?
I replaced part # 84140-26040 when my high beams started acting up and that fixed the issue. Search ebay and the Toyota parts suppliers for the best price.
That seems to just be the dimmer switch. Which would fix one problem but my turn signals aren’t working either
Treasure hunt.
Toyota calls it a Combination switch.
Depending on what's wrong with it you may be able to fix it.
Check out 4crawler.com.
I found an entire switch setup (turn and wiper) on ebay for around 75$ for my 2nd gen. I would start there especially if you can find the part number from toyota and then search ebay/amazon.
Do I have to get one with an A07 plug like mine has or will any fit?
Seriously, they are super easy to fix!
9/10 of the many I had to fix it just needed to be cleaned because the contact had corrosion.
4crawler has detailed walkthrough on how to test and fix!
Sent from my XT1635-01 using Tapatalk
stc6306
