Twist key twice to unlock doors part number?
calimobber
Member
Does anyone know the part number for the switch inside the door lock system that when you turn the key twice it unlocks all the doors?
When I replaced the door lock motors a few years back I broke the clip so the part lo longer locks on and moves with the lock when I turn the key. I cant seem to find it anywhere and want to replace it.
LOCK CYLINDER SET. 4Runner | Marietta Toyota, Marietta GA
Humm... I can see the part for the back door in the diagram but it doesnt show it for the driver and passenger door. I wonder of its one of those things that only comes in a package deal when you buy the door lock setup.
The part looks like the one under number 5- that says refer to fif 84-01 pnc 84830
I guess I can just call the dealer and ask.
Im not sure, I have a 1998 without alarm system and I only have a switch on the rear door lock. My front locks don't have the switch but I can do the single/double lock with both front doors.
So if my doors don't do anything when I put my key in my drivers door this could be the part I need?
Sent from my SM-N975U using Tapatalk
Well for me it did. My doors were working fine before. Then tweekers jacked my door lock, nothing missing (I don't keep anything in there). And after that I couldn't do the all doors unlock with the key in the drivers door. At that same time, passenger door key lock is fine with the all doors unlock. I also couldn't get the rig to go into programing mode for new remotes.
Took apart the door and found the broken clip holding the probe at the end of the lock. Got that part from a part out on this site. Put it on and now I got my remotes programed and can do all doors unlock from the drivers door lock.
youngrk
