Two center console questions
Scuba6
Member
I have two questions concerning the center console that I have yet to find answers to:
1) What is the part number for the small divider in the console and a source to purchase it? I would like to buy a second one for a project, but can’t seem to find that part number in the 5th Gen parts manual. The part is shown as #1 (black arrow) in the picture below.
2) Can someone who has disassembled the console tell me what is under the raised hump inside our console? (Red arrow, labeled #2) I know the wiring for the 120v plug is on side closest to the passenger, but is there anything under the side closest to the coin holder? My end goal would be to cut a 1.5” x 1.5” hole in the side (right where there arrow points) so that an “L shaped” item could lie at the bottom of the console and protrude slightly into this void.
I know that second question is might be confusing, so hopefully the picture helps. Thanks!!
Consolepicture.png~original
check out the FSM in my sig.
it looks to be for allowing clearance space for the socket for the bottom of the 120V power outlet. See section Power Source/Network--Battery/Charging--CENTER POWER OUTLET SOCKET for a picture of this.
as for the part number for the divider?? Have you tried the dealer yet?
1. I couldn't find a part number in the parts catalog. That probably means it just comes with another assembly, ask the dealer.
2. There really isn't anything under there. The outlet is in half of it the rest is empty. I mounted the box for my Cobra radio under there. You can see the silver box on the left hand side.
648095bd.jpg~original
Ryan - The picture you provided helps a lot, thanks.
EDIT / UPDATE: The Parts Dept at my dealer couldn't find a part # either. They were looking at the same diagrams that we've all looked at thanks to Nash. They did a pretty detailed job looking and were surprised they couldn't find it.
I guess it's a junk yard if I decide I want the piece bad enough.
Thanks to both of you.
ian2328
