Two foglight questions!!!
Jeff T
Member
1) Can the foglights be wired to turn on without the headlights???
2) What can I change the bulb to, to get more of a driving light?
1) Follow J.A.'s instructions to modify your foglights - Toyota 4Runner Independent use of Fog Light Mod
2) Install HID lights. DDMTuning sells both 35W and 55W. I am using 55W in both the Driving(projection) and Fog. Fog light requires a harness kit to use HID which you can buy from DDM also.
Yes, check my sig for link. BTW there's other threads on this, search is your friend.
Well you can put HID's in there, i've got 3000k HID's for a real fog effect for inclement weather. As for your question about a driving light, I don't beleive they are aimed anywhere near where a driving light would be. Given the purpose is fog - I would doubt the beam pattern would be a useful driving light even if you could re-aim them sufficiently.
55w kits in the fog housing can burn, happen to me so far, thats why i have to downgrade to 35w, it doess seem less washed out, meaning more of a darker yellow on 3000k, 55w makes it less yellow, have some white. only a good eye can tell the difference.
Did step one of JA's mod today. Went easy as could be and now the fog lights are on when I want them one!
One sidenote, I bent the tab slowly and cautiously and I still had on side of the leg break away from the fuse...
