Ugh, another coolant leak. <<<PICS>>>
Can you post a picture of the back side of the radiator showing the lower hose connection and the transmission cooler port? It very well could be the trans cooler beginning to leak and you definately don't want to drive it if it is. A new transmission is very expensive. When it cools down check the coolant in the radiator and see if its milky.
Search "strawberry milkshake"
"When the two fluids mix, the mixture overflows into the coolant overflow reservoir with a fluid that looks a lot like a strawberry milkshake (may be a different color if you dont have TOYOTA red coolant..). If the mixture manages to return to the transmission, it can cause catastrophic damage. Often resulting in a ruined transmission. When a milkshake strikes, you will notice your transmission will not want to shift or hold a gear when moving. "
I'm currently running a yellow Prestone mix. The reservoir fluid looks fine, not milky at all. I have no problems shifting or staying in gear. Maaaan, don't freak me out like that. :rockthrow:
Haha! I figured even mentioning tranny fluid would freak you out.
Here, do this: go out and buy some Gunk Engine Degreaser.
Follow the directions on can(You can find this stuff @ AutoZone, AdvanceAuto, OReillys, etc). Get your engine bay nice and clean. Degrease everything. Let your bay dry and then take pics. The leaking spot will then stand out to you and you can locate it. Post pics and i can continue to help!
johnnya
