Ultimate lift and LR UCA alignment specs
Diesel_Dog
i just installed a toytec ultimate lift and LR UCAs. Set the UCAs in the D position per the instructions, pulled the ball joint as far towards the outside as I could and took it in for an alignment.
I asked that they set the caster to 4 or more and then get everything else as close to zero as possible.
The results:
Caster L 3.5 R 4.0
Camber L 0.4 R 0.5
Toe L 0.1 R 0.07
Am I in the ball park for what to expect from the aftermarket UCAs? It doesn't appear that they adjusted the Caster setting on the UCA. Should I go back and ask that they get me more in the 4 range for the left side caster?
I'll note that they charged extra because it had a "Lift kit"
I plan to put 285/70/17s on a FN wheel Fx pro rims when the snow is gone. I would like to avoid any rubbing (or at least do what I can with the UCAs)
Thanks for any insight you folks can provide.
Maybe I should simply my question: is 4 degrees of positive camber over hyped? If someone has less, say 3.5, will one need a body chop, fender liner mod, and remove the mud flaps to run 285s?
