Ultragauge, Scangauge, and 2-1/16" Gauge Mounts
Yep, another happy camper here Leon!
Took some time out from other stuff and Installed the scan gauge bracket today......all of 10 minutes which includes 3 minutes of just admiring the well designed bracket/mounting setup.
Pleasure to do business with you, a real gentleman!
[MENTION=198376]4Runner4Leon[/MENTION],
I just installed the scangauge bracket that I ordered from you, and wanted to say Thank you for designing and selling such a great product. I have had my SC mounted on my dash for 3+ years and never liked, it but didn't have a better solution, as to where or how to mount in until now. I love the location your bracket places it in. Also the installation, couldn't be easier.
Great job!
Thanks again
Durwin
[MENTION=102168]owyheerat[/MENTION] and [MENTION=118429]Sarki[/MENTION], thanks for the feedback and the kind words! I worked hard to come up with a clever and robust design for these mounts, and it is super rewarding to get such nice feedback from folks like you. Makes all the hard work and time invested worthwhile! Enjoy :)!
[MENTION=198376]4Runner4Leon[/MENTION], where do you feed the data cable to get to the OBDII port? I really like that mount and location.
Sorry if this has been covered.
Thanks!
JT
Thanks!
JT
JT, I route the cable behind the a-pillar, down to below the dash, and then under the dash over to the OBDII port by the gas pedal. It's very straightforward once you get around to it.
Updating this thread to mention that all mounts are now being supplied with a high strength M6x1.0 screw to replace the OEM A-pillar Phillips screw. Those original low tensile strength screws had loctite applied during assembly, which makes for a high likelihood of damage during removal.
Instead of just providing information on what replacement screws to get in case of damage, all mounts now come with the improved high-strength screw included.
Ordered both the mount and UG MX today. My main need is fuel monitoring b/c the factory gauge has been bonkers for a couple of years.
Once you calibrate the UG for your truck, it'll tell you how much fuel you have left to within 0.1 gal accuracy. I hardly ever look at my fuel gauge anymore, it also goes bonkers after about the 1/4 mark. The UG is dead accurate.
The add-on 2-1/16" gauge holders are now available - these attach to the Ultragauge/Scangauge mount, and can hold one or two gauges (boost, trans temp, oil press/temp, etc). A couple of examples below:
For the 5th Gen mod, you might want to try one of our mounts for the Tacoma (below). They use a standoff to hold the mount (instead of being sandwiched between the A-pillar and the handle, like the 3rd Gen 4Runner mounts).
They work great for 1st and 2nd Gen Tacos, and for 3rd Gen Tacos that have the aftermarket A-pillar handle. They also work in the 1st Gen Tundra.
I don't know if they'll point the gauge correctly, because Toyota seems to use different angles for all the A-pillar holes. But you can try, and if it doesn't work, you can return it.
Does a 2 1/16” gauge mount exist, without the Scangauge or ultra gauge mount?
There are A-pillar pods for 2-1/16" gauges. We thought of making something like this, but there didn't seem to be enough takers to make it worthwhile:
Another option is our soon-to-be released phone mounts, which can use the add-on gauge holder:
Do you have any side images of the 2nd photo w/ the ultra gauge and 2 1/16" gauge below it? Just curious how much the gauge sticks out.
Here are a couple of photos to help with that. First is a side view of just the UG installed:
The gauge mount holds the front of the gauge roughly flush with the front of the UG, the rest of the gauge sits further back:
Awesome thanks! What the price on the scangauge mount w/ single gauge combo?
AndiGarage
