unbelievable.....
TCLLC
for reasons i dont want to get into...
i was talking to my dealer about taking my truck in for plugs, just plugs...
$720.00
This is a longitudinal V6 with a lot of room under the hood. If you don't want to change em yourself, how much would a decent independent shop possibly charge?
I just did mine about 4 months ago, it kinda sucks if you dont take the intake off but its do'able. With the correct length wobble extensions and a few scratched knuckles it takes about an hour to do all 6 without taking the intake off.
The first time i did mine i took the intake off, and honestly its stupid easy with the intake off, but taking the intake off takes just as much or more time than it takes to just tough it out without taking the intake off.
Buy the plugs from toyota, the Denso. The NGK dont last as long. Do it yourself and save a pile of money you need a 10mm socket and a spark plug socket, a 3/8 ratchet and a few extensions and a magnetic tool in case one of the spark plugs falls out of the spark plug socket. About an hours time and you will be done.
My spark plugs were done 3 years ago for $730 canadian. add inflation and a bit of greed and your quote doesn't seem that far fetched. but then again my pricing included a throttle body cleaning etc. but still doesn't seem that far fetched
Just for the plugs? lol
I got a better set of IX plugs for $37.50 on Amazon :wof:
Lots of counterfeit plugs on Ebay and Amazon. If the price is significantly lower than a brick & mortar store like Advance auto parts, Autozone, etc. it's a good bet the plugs are not genuine.
So what's the average lifespan of the original plugs anyway?
They will last well into the 150K+ range, normally see them burning out around 190,000-200,000 but have seen / heard of instances where people didnt replace them until one burnt out around 250,000
drivers side, normally the middle or rear cylinder is always the one that shows the most wear on the electrode. Cant confirm why, but they will typically go well over 100K miles.
I think I'd be more concerned about actually getting them out at 190-200k.
Absolutely there are, however if you research and weed through the imitations there are legit ones out there. I got 6 NGK Iridium IX's for that price
I did my plugs myself in less than an hour. Total cost was roughly $125 CAD for plugs plus $10 for the beer consumed.
Even with removing the air intake and the air pump on each side, it was a super easy job. The only plug that was kind of a pain was the drivers side closest to the firewall, but a combo of extensions and a wobble adapter took care of that problem.
if doing it yourself isn't an option, go buy the plugs yourself and ask a local trusted mechanic for a quote. I can't imagine an honest mechanic charging more than 1.5 or 2 hours tops, but maybe i'm wrong.
freddygino
