Understanding offset.
Doc2012
Senior Member
Im not up on wheels. Not very much anyway.
Help me understand this.
I’m running the 17x7.5 in the first pic.
I was running the stock 5-stars in the second.
So, the 17s have a 30mm offset.
The 16s have 15mm offset.
So I would meet an extra 15mm to make them sit in the same ‘spot’?
I was running 315/75/16 with 1.25” Spidertrax. No rubbing issues.
Bumped up to 37x12.5x17, and slightly rub the UCA.
If I added 15mm, that would negate the rubbing, right?
But, 15mm is over half an inch, which would need to be a 2.25” spacer, which they don’t make.
So I need to get some aftermarket UCAs.
Right?
Your math is good. A 2" spacer will put you a couple millimeters closer inboard than your original setup, which really should not make a difference. I did not compare the actual tire size head to head which under low pressure could make a bigger difference
Current wheels have 5.43" backspace and new have 4.59" backspace. So if you want the same clearance you would need a .84" wider spacer. So a 2" is onlu going to decrease your UCA clearance by .09". I have some shaved UCAs for really cheap if you need more clearance.
D'Angelo
